Engine dying....
Old Oct 21, 2009 | 05:38 PM
lspencer534's Avatar
lspencer534
St. Jude Donor '09-'10
Default Engine dying....
Here's what I did today: Installed N-11 off-road exhaust on my '67 (which are still too quiet for my taste), replaced wires going to the starter since they were getting charred, and crimped a loose end of a battery cable. It's a 427/400, 3 2-barrels of course, automatic. Now when I approach a stop the engine dies when the rpms lower to about 1200. Cranks right up, does it again next stop. It's a sudden loss of engine power, no stumbling or warning.
That's all I did to it. What could be the problem? Also, what is the cure for shielding the wires near the exhaust manifold?
Old Oct 21, 2009 | 05:57 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
I would inspect the area(s) where you worked on the car and see if anything is disconnected. Vacuum lines?
Old Oct 21, 2009 | 09:06 PM
stingrayl76's Avatar
stingrayl76
That was my first thought.
Old Oct 21, 2009 | 09:39 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Might be the vacuum led to the distributor. This might be a stretch, but you may have actually leaned out the center carb with the new exhaust. Check your idle mixture screws. I think GM sell a shield, but I know Moroso has one. Dennis
To Engine dying....
