Half shaft alignment
Old Oct 24, 2009 | 07:57 AM
Jackfit's Avatar
Jackfit
Default Half shaft alignment
I had a new rear spring installed a few years ago, and now that I am driving my car every day, I have notice a squeak from the rear. The new spring has my car sitting higher than I think it should. 25" Front, 28"back. (215/70 15 tires).
The angle of the haft shafts should be ? Could it be the u-joints not happy with the extra height.
I have read that many of the replacement springs set the car higher .
Any pictures of what a good angle looks like?
Jack
Old Oct 24, 2009 | 08:48 AM
DansYellow66's Avatar
DansYellow66
Just for the purpose of good U-joint operation there should be some angle, I guess at least 3 degrees. Beyond that I guess whatever angle it takes to set the suspension to the heigth range described in the service manual.
Old Oct 24, 2009 | 10:37 AM
JohnZ's Avatar
JohnZ
The correct ride heights (and how to measure them) are shown in your Assembly Manual at the end of UPC 3 and UPC 4; the "J" and "K" dimensions are from the bottom of the rocker molding to ground (with stock 27"-tall tires), and the "Z" and "D" heights measure suspension height independent of tire size.
Rear wheel opening lip 3" higher than the front will show that the rear is out-of-spec high. Mine is in spec; photo below shows the rear spring and half-shafts with the spare tire and carrier removed - it sits a little lower with them installed.
Old Oct 24, 2009 | 02:08 PM
Jackfit's Avatar
Jackfit
Default Off by 2.7 "
Hi John,
Thank you for your reply. I just measured the "D" spec and there is a 2.7" deviance from spec in book. It is quite noticeable from the side view of car. As stated, at the wheel well lip , front to back difference is about 3 " .
How do I fix it. Can it be fixed or do I need a proper rear spring that will give the correct ht. If so, where are they available.
I actually like the look, but you can see and 1' or 2" above my rear wheel, when looking from side. Looked good 40 years ago, but not now.
Jack
Old Oct 24, 2009 | 04:26 PM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
When I first installed my rear spring 5 years ago, the rear was high also. It settled out after about a year. Now the car sits as it should.
If you have threads left on the spring bolts, you could run the nuts down to the cotter pins. That should lower the rear a little for now.
Old Oct 24, 2009 | 08:41 PM
CWPASADENA's Avatar
CWPASADENA
How about installing longer tie bolts. Get your self some Grade Eight bolts that are longer and grade eight nylock self locking nuts. Works great. I have been doing it for years. if you are concerned about a nut backing off, you can also use lock tight or double nut it. You can adjust the ride hight to where ever you want it.
Chris, CWPASADENA
Old Oct 24, 2009 | 10:48 PM
Jackfit's Avatar
Jackfit
Default How do you do that?
Chris, CWPASADENA
Thanks for the suggestion. I don't know how to do it safely. Do you have to chain or clamp the spring. I will read the books on it tomorrow. If you have a procedure , feel free to let me know.
Jack
To Half shaft alignment
