Have a 63 with a build date of B2. What would be an acceptable date range code for an engine block??
Also when painting an engine block do you use a primer?? It takes several coats to cover with the spray bombs.What is the best approach??
Dave
B2 is the second week of October; a block for a car built on that date would typically have a casting date 2-6 weeks prior, although NCRS allows up to six months prior.
John does NCRS allow 6 months prior on all dated items? IE starter, alternator, master cylinder, rear end, distributor, FI unit?
Cheers,
Bob
The short answer is yes, although if LOTS of items are way out close to six months (as opposed to the more typical 2-6 weeks or so), it invites further scrutiny. Glass is an exception - up to a year is allowed, as it was made in infrequent "batches" due to low volume.
