Would removing those straps/bands/clamps on the spring allow the car to sit any lower?
I went out to car and noticed that I did have bands on my springs. They were the shipping bands that should have been removed during installation. I took them off. No noticeable difference in height. But I haven't moved car yet this morning. Later this month I will install the rubber cushions. I should loose about 3/4 to 1 " . Each poly is about 3/8 or more thicker than rubber. I have not noticed any real difference in smoothest of ride poly vs. rubber.
Jack
the poly's will outlast the rubbers and not affect the ride.....how much thread do you have left on the bolts? ...
Hi,
I have the nut all the way down on bolts save about 1/8 " , just enough protruding to secure nut. The car looks much better and the squeak from my rear has stopped. I am sure the shop ordered a replacement spring and we know some give a higher ride than the original spring. As I looked at pictures of other springs and as one member pointed out about the clamps, I realized that they were not removed. My spring does have two screws (center of spring edge to edge ) that hold the 3rd and 4th and 5th and 6th bands together, is that normal? Or just on replacement springs. In other photos in this post I don't see them.
Jack
Reason: photo
Jack
No, not normal. There should be just one bolt in the center to hold the spring pack together.
The leaves have to be able so slide along each other as the spring flexes through an arc. This is why they have the vinyl liners to promote this sliding and reduce the squeaking as they do slide.
Let's just hope that those "screws/rivets/?" are going into slotted holes that still allow for this differential movement rather than just round holes that would cause the leaves to bind up.
i have never seen those screws either but im a young 64......wtf...anybody seen those before??
I am also a NCRS member and one of the member said they are plastic retainers to hold the liners in place. Again I have not seen them on any of the pictures posted. Are they just on replacement springs?
I will go out and take a better picture of them. I will also see if they are plastic or metal.
so jack, are they indeed metal screws or just the head of the plastic liner that looks like a screw??
They are part of the liner, I believe the liner (only 2" long ) is made of a slippery plastic and they part of the molded material. They do have a slot, but it is there so it can be compressed to go into spring hole.
Jack
Reason: material add
