Door Panel Fitting Help
Old Nov 6, 2009 | 07:17 PM
salty_waders's Avatar
salty_waders
Default Door Panel Fitting Help
Trying to install my new door panels from Wilcox on my '65 convertible. The panel "hooks" over the top of the door from the vent window to the rear of the door. Does it also hook over the top of the door at the front, below the vent window? Thanks!! Also, any other install tips or pictures will be welcome.
Old Nov 6, 2009 | 07:35 PM
woodsdesign's Avatar
woodsdesign
It is common to have to grind the leading edge to get a good fit. I had the same problem.
ren's Avatar
ren
Yes, Thats how it fits. I did the same thing on my 63 a few years ago. Had to do a little tweeking with a rubber mallet. Very happy with Wilcox panels. Take your time-I'm sure that it will fit properly.
Old Nov 6, 2009 | 08:16 PM
salty_waders
So it does hook over the top of the door under the vent window?
Old Nov 6, 2009 | 08:30 PM
Mike Geary's Avatar
Mike Geary
Default Salty...
the originals do not hook over the vent window area, nor do my old CA repros or AK repros. I don't see how they could, given the triangular cover plate over the vent regulator.
Getting a tight fit (small gap) in the vent window area has always been a problem with repro panels. The new CA panels are said to be improved compared to other repros.
Old Nov 6, 2009 | 09:27 PM
robert miller's Avatar
robert miller
they do not. Just all of the area on the glass window. up and down part.
Old Nov 6, 2009 | 10:17 PM
54greg's Avatar
54greg
I had to cut the metal lip of the door panel from the corner of the vent window to the main window glass. My panels took quite a bit of massaging
Old Nov 7, 2009 | 10:46 AM
salty_waders
Thanks guys! I'll let you know how they turn out
Old Nov 8, 2009 | 09:58 PM
salty_waders
The panels took a little but fit fairly well. I have two questions: the vent window cranks are not centered on the raised pad very well. Also, I had to really smash the panel down to get the cranks to click on. Are these common with repo panels? Thanks!
Old Nov 9, 2009 | 09:14 AM
Mike Geary's Avatar
Mike Geary
Default Window Crank Fitment Issues
Salty:
My CA panels (installed recently) were produced in the early 90's and yes they had the same issues. Also, the lock **** hole was off quite a bit, forcing me to move the mechanism on the door.
To get the cranks to seat, I had to heat up the panel.
Mike
To Door Panel Fitting Help
