Crate Engines
Old Nov 7, 2009 | 07:36 PM
tomkat17201's Avatar
tomkat17201
Default Crate Engines
Has anyone installed a Ram jet 350 in a midyear?If so how do you like it & did you have any clearance issues with SB hood?
Old Nov 7, 2009 | 10:12 PM
65Tuxedo's Avatar
65Tuxedo
Thought about it, but every source said it would take BB hood, which I did not want, so I went with the ZZ4. Wanted the Ramjet, since my car was originally a fuelie. If you get one to fit, I would like to hear from you. Love the ZZ4, but still would like the FI.
Old Nov 7, 2009 | 11:02 PM
JLMICCA's Avatar
JLMICCA
I believe Corvette Fever Magazine did a ramjet install article series a couple of years back (may be available online). From recollection, they did require a swap to a big block hood...wasn't even close. I have a build 350 in my '63 restomod with a small block hood. I am considering the new self tuning throttle body FI system from FAST. Recently reviewed in HotRod...looks like a good addition to a ZZ4.
Old Nov 8, 2009 | 09:20 AM
vettnut's Avatar
vettnut
Check this out. He is a forum member.http://www.carols62.com/carols62.html
DG
Old Nov 8, 2009 | 02:23 PM
Loren Smith's Avatar
Loren Smith
I think the Edelbrock Pro-Flo XT is at least an inch shorter than the Ramjet, and might fit:
http://www.edelbrock.com/automotive_...xt_intro.shtml
Here's another option, albeit pricey:
http://www.azspeed-marine.com/sudrtopinsy.html
Old Nov 8, 2009 | 08:02 PM
rgs's Avatar
rgs
My brother put a ramjet in his 65. The small block hood would clear if you cut part of the under support structure. He chose to go the route of the BB hood, but put the FI badges on the fenders.
Old Nov 9, 2009 | 08:09 AM
Frapps's Avatar
Frapps
I have one in my 64 and love it. Of course there were issues (like a new gas tank and new fuels lines) but it was worth it. My SB hood did not clear the throttle body. I trimmed back the inner bracing near the TB but could never get the hood to clear. Even after it was painted the hood came in contact with the TB although just slightly. I didn't want to completely cut out the bracing, so I was just running around with the hood open.
Just picked up a repro 67 BB hood and am now in the process of fitting it for paint. This is fine with me as I like the look of that hood better than the stock 64.
Love the Ramjet.
Frapps
Old Nov 9, 2009 | 02:54 PM
tomkat17201
Default After market 67 BB hood for Ram Jet 350
Any recommendations on vendors to purchase hood?
Old Nov 9, 2009 | 05:40 PM
Wilkinshc's Avatar
Wilkinshc
If your looking at Crate Motors maybe this would be a better option:
http://www.gmperformanceparts.com/ho...4=NovemberFuel
Chuck
Old Nov 9, 2009 | 08:52 PM
fullcontrol's Avatar
fullcontrol
Paid Senior Member
Chuck
And here is the introduction video from SEMA last week.
http://video.streetlegaltv.com/video....php?mId=10942
Old Nov 10, 2009 | 02:02 AM
CWerner's Avatar
CWerner
I've got a ZZ4 with a TPIS MiniRam on it. Fits without any issues.
Old Nov 10, 2009 | 09:36 AM
JPB04619's Avatar
JPB04619
Default zz4
not to steal your thread but can any one tell me what dust shield fits a zz4 attached to the original 64 muncie with the stock bellhousing thanks john b
Old Nov 10, 2009 | 01:05 PM
narlee's Avatar
narlee
It doesn't fit with the smallblock hood.
Old Nov 15, 2009 | 06:20 PM
Frapps's Avatar
Frapps
I bought mine from Hannemann Fiberglass, Inc. in Azusa, Ca. Drop the space and the "Inc", add the ".com"
Old Nov 15, 2009 | 07:58 PM
DesertSpider's Avatar
DesertSpider
I've been looking at Crates as well lately and am pondering the same dilemma (how to get the thing to fit under a SB hood)...
DS
Old Nov 16, 2009 | 09:31 AM
Frapps's Avatar
Frapps
DS
Easy, cut out the center section of the inner reinforcement. The interference is right where the throttle body bolts to main housing AND where the accelerator cable loops around the pulley. I modified my hood twice, repainted and it still hits. I lowered the center section to a point where I thought "any more and it won't have any strength or purpose".
Actually if you didn't have to worry about originality, you could cut out the center section and not lose any structural integrity. Just look at the 67 BB hood, the reinforcement is only around the outer edge.
Don't forget about installing a return fuel line and an electric pump. And, oh yeah, I had a problem with the humongous balancer forcing the pulley into the frame. I had to run a smaller pulley and even then only have about a quarter inch of clearance (makes putting the belt on a real biotch.
Think about extending the wire on the two ECM plugs so that you can get the ECM inside or away from the engine.
Those were the major obstacles.
Frapps
Old Nov 16, 2009 | 11:05 AM
ehjr02's Avatar
ehjr02
I've got the Edelbrock Pro-Flo XT EFI system in my 63, and I can confirm that it will not fit under the hood. Looked hard at cutting out the underhood support bracing, but that just won't gain enough clearance.
My car's at Mongoose Motorsports near Akron getting fitted with a Grand Sport style 2-hole Nassau hood, but it looks like any BB hood would fit.
To Crate Engines
Old Nov 16, 2009 | 11:27 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Frapps
I wouldn't worry too much about leaving the Ram Jet 350 ECM in the stock location. I've been running mine mounted on the rear of the engine (stock location) for almost 7 years and 35,000 miles with no problem.
Charles
Old Nov 16, 2009 | 01:18 PM
Vogie's Avatar
Vogie
DS
Your avitar is equipped with the big block hood. Is that your car?
Old Nov 17, 2009 | 07:53 AM
Frapps's Avatar
Frapps
Charles
Charles,
I suggested that because of aesthetics, space issues and laptop connectivity, not because the stock location is a dangerous place.
What was your final solution on the fast idle issue?
Frapps
