PB Conversion Kits for 63
Old Nov 11, 2009 | 12:26 PM
73737373's Avatar
73737373
Default PB Conversion Kits for 63
Anyone have any experience with one of these? Saw in one of the catalogs that the hood has to be modified on a 63 for the kit to work.
Old Nov 11, 2009 | 02:18 PM
John S 1961's Avatar
John S 1961
you probably have to make room for a dual master, without the Power booster it may fit without cutting the hood liner
Old Nov 11, 2009 | 05:50 PM
Stingray1967's Avatar
Stingray1967
A few things.
First, I don't know 63s very well.
Second, I THINK all midyear small block hoods were basically the same up near the firewall.
Third, for power brake 63s, I think I read on here the other day that the standard thumb screw top to the master cylinder was changed to a different, lower profile design that would clear the hood.
Fourth, on power brake 63s that were NOT Z06s, they still had the single piston master cylinder.
Old Nov 11, 2009 | 08:06 PM
uncle427's Avatar
uncle427
The 64-7 style boosters will not fit under a 63 only hood. There is a rekief in the frames of all 64-7 hoods just above the booster shells joint.
In 64, the relief is added BUT one cannot use a dual master cylinder as the 65-7 hoods have an additional relief added in the cross brace of the hood frame where it passes over the top of the front of the cap on the dual units.
That relief is not there in 63 or 64 hoods. Be careful what outfit you are dealing with when asking for fitment advice. I know of one case where the customer was told to bend the brackets down so it would fit.
Scary.....................
Old Nov 11, 2009 | 08:31 PM
toddalin's Avatar
toddalin
I've got a '66 hood for sale that would work.
Old Nov 11, 2009 | 09:36 PM
John S 1961
Bend brackets? How much? Which Brackets? that doesnt sound that scary! A little Bubba maybe!!!!!!
Old Nov 11, 2009 | 09:47 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
I bought a conversion from CPP that was a booster and dual reservoir master cylinder. When I looked at the bracket I called them and told them it wouldn't fit. They told me it would and I was trying to use the wrong bolt holes. They told me I was to use the top 2 bolts on the master that was in the car and drill 2 new holes for the top ones on the new bracket.
I accepted this as fact, but I haven't put it in yet. If I have to alter my hood, I will be angry. If they don't take it back I'll try selling it on eBay or using just the master cylinder without the booster. I bought it about a year ago and never installed it. It makes me mad when a vendor gives you bad info because they don't know the differences between '63 and older mid-years.
Old Nov 12, 2009 | 12:14 AM
73737373's Avatar
73737373
Many thanks. The last thing I want to do is start the kabuki dance of replacing hoods, bending brackets and drilling holes. If anyone comes across a single kit that comes w/all the right stuff and it fits, pls advise. Thanks.
Old Nov 12, 2009 | 10:48 PM
uncle427's Avatar
uncle427
There are other style boosters available from the same vendor mentioned here that are not of stock design but are functional and will clear the 63-4 hoods and the associated problems.
To PB Conversion Kits for 63
