Backfiring issue
Good luck!
Gerry
Edit: By the way, congrats on the new car and welcome to the forum!
Last winter my 62 would start & Idle fine, but when I drove it it would backfire both through the exhaust & ocassionally through the carb. It was a moist distributor cap, which causes the spark to fly everywhere inside the cap. I got a heavy duty cap & no problems since here in wet Seattle.
Don
How long will the car sit and idle? Can you start it and it idle for 15 minutes or more?
Now while it is sitting, can you bring the engine up to around 2500 rpm for 3 or 4 minutes without this happening?
If you can't to either of these, then maybe it is fuel related. The ride on the trailer may have dislodged something that has stuck under the needle in the carb, such that fuel is being blocked. If it idles, it would use fuel slowly enough to run fine, but running faster, fuel is used faster than it can be replenished in the carb blow.
A WCFB is really a simple carb to work on, but it is probably beyond you right now. You can decide if you want to open it or not. The biggest point of failure for you working on one is getting the accelerator pump in correctly. The originals had leather cups that can turn over (unfold like an umbrella in a strong wind) but I think most have been replaced with rubber by now.
If it will idle for long periods and will run while revving the engine, and only quits and backfires when driving it, then it is probably electrical in the ignition, although I would have thought it had dried out by now.
I think it is more likely the condenser breaking down or the coil failing than water. To check if the condenser is breaking down, simply disconnect the condenser wire from the coil. If it runs fine, then get a new condenser.
Oh yes, missed this post. I think it is more likely fuel related, since you do run some.
Last edited by Procrastination Racing; Nov 13, 2009 at 01:15 AM. Reason: Missed Secret Squirrel's post
Some people love their Pertronix, others hate them. The trouble is that they either work 100% or the fail completely like several that have posted here. I would keep all the parts to convert it back to points in my glove box just in case so you aren't left walking.
Jim
