C1 Handling
But it was still fast enough to get air under the front tires, but not the whole car.
That whole area was real nice for a Sunday drive.
Nothing like that around here in FLa. That's one reason why i don't drive much here. What is the point? Also at 57, my back now has a speed bump warning
So guys, if you buy a horse, don't complain it won't keep up with traffic on I95. Take it on a narrow mountain pass where no car can fit. Feed it some oats. Don't put on a hardtop, add AC, and then complain of a foul smell when he passes gas.
I sure miss the snow around Christmas time, and hunting with my old buddies, but then not having to scrape the frost & snow from my windshield or shoveling my sidewalks is well appreciated. It's still very difficult to have Christmas with green grass, palm trees, wearing just a sweater. I get a real kick when it drops below 50 degrees and floridians walk around in sub-zero coats wearing gloves and ear muffs ha ha ha, what a bunch of wimps down here...
Overall, it's a a good trade off. Peace!rustylugnuts
I think you know Frank.
Case closed. The Biscayne wallows and dives and rolls like a pig. The Corvette, in comparison, is on rails.
Doug
I drove a 1960 Impala years back as a teen so I was far from gentle with it and remember having to hang on tight to the steering wheel to avoid sliding across the bench seat on hard cornering...used to make
killer right turns so my dates had to slide up next to me too...the car was definitely a pig in the twistys. My '61 (thank goodness) is not THAT bad...
I believe many complaints are from cars that need work.
Larry
Jim
Jim
In 1955 and 1956, the future of the Corvette was in serious doubt.
Doug
Jim
A 300SL gullwing coupe with a 283 and its IRS probably would have run away and hidden from a '50s C1, but fortunately they only had 183 cubes that were just getting on the cam at the end of a typical U.S. road race course straight. Torquey C1s would run away from them on the straights and they couldn't catch up.
Later, the C2 was the answer for taking care of E-Type Jags, but the unsophisticated small-block Cobra pulled a C1, outdragging the Sting Rays with its V8 and much lighter weight.
Thus, I'm not willing to risk body damage. If I blow an engine, shred a Muncie or rearend, I'll rebuild it or put in a spare. I can do anything to the suspension, brakes and electrical system------------BUT NO BODY WORK! YUK! Thus, even a calm vintage racing exercise is out.Now, I have considered setting up the 56 for some fairly serious drag racing. That doesn't bother me, because as I said, if I destroy an engine or something in the driveline, I'm OK with those repairs.
Tom Parsons
Once i test drove a THEN new 88 FIERO, salesman riding along.
He says TRY OUT THE HANDLING
me: you want me to see how it handles?
him: YES
me; are you sure?
him: GO RIGHT AHEAD, TRY WHATEVER YOU LIKE
So i give him my version of GONE IN SIXTY SECONDS.
He says nothing.
He gets out, white as a sheet.
him: well i'm sure you won't buy THIS car.
me: Why?
him: you beat the crap out of it.
me: you said TEST THE HANDLING. IT handles GREAT, way better than i expected.
him: walks away mumbling, doesn't try to close sale.
so in my mind, i'm impressed, it handles like my 61. What does good "handling" mean? At the cars' limit, i'm in control, and it doesn't take any practice to find the limit, and it's fun, and doesn't spin out or bottom out, and it is not at all dangerous. That's good handling.
But, i don't think any 2 people would agree with each other, let alone me,
So, define
what is your "good handling"?
Just my 2 cents, Dave
Both have had full nut and bolt restorations, including all suspension components. Both are bone stock and ride on original equivalent sized radials, both have power nothing, but the Mustang does have the original manual front disks (standard as you know on the GT in '65).
I gotta say that I find that the Mustang drives eons ahead of the '62, mostly in terms of the steering, precision of the front suspension, and of course the brakes. I have no problem coming into a corner a little hot in the Mustang, but the imprecision of the Vette front end always causes me to back down (probably a good thing
). Now don't get me wrong, I appreciate the '62 for what it is, but the front suspension was designed for the Chev sedan in the mid forties, or maybe even prewar?
Even though the Mustang uses lowly early sixties Falcon hardware, I find the feedback and steering response much closer to the cars of today. The feedback is linear right up to it's limited max, I can trust what it's telling me.
I know that any modern day econobox could out handle it no sweat, but man I find it fun to drive it a little con brio.
Paul
Paul
Paul, why don't you weigh the 65 GT against an equally equipped 65 Corvette, that would be fair, or weigh your 62 Corvette against a 62 equally equipped Falcon.....oh sorry! That doesn't exist.... Let's keep it close to the same years for this to be fair.....
rustylugnuts
The fastback (the beast!) on the other hand was an all manual, 4 speed brute with a 'street boss' engine (souped up 289 with 351 heads). There were too many mods to the suspension to list here...beyond what Shelby did with them even. My C1 can't compare to this car which I specifically set up to drive 'on the edge'.... I could flip the fastback into a 4-wheel drift and go round corners steering with just the accelerator. Not sure if I could do it with the bone stock '61 vette but I'm sure it would be a life-changing experience...
The above comments would be a more accurate comparison... And you're a lucky man to have both a vintage vette AND Mustang....I had to sell one to get the other...
John Neas has one of the ORIGINAL, factory prepared (as in Chevrolet in Detroit, NOT an aftermarket vendor) 56 Sebring race cars. That car is pure gutted!!! It went to Sebring with almost no trim, no guts. The trunk is empty, no right seat, no interior, the doors are empty shells. No washers, wipers, radio, heater, windshield, top, etc, etc. Those were the only production line cars to be modified AND lightened. The 57 Sebring cars had windshields and hardtops.
With a 283, or even a 327 transplant, the 56 Sebring cars would be awsome. True, they had the stock type suspension, but with approx 600+lbs removed, the handling changed. Also, they had cut down steering columns for more arm maneuvering.
I built the std bore 265 and dual WCFBs in that car and it runs great! But it just needs cubes for lower end torque. It doesn't even start to work until about 4000rpm-----------------and John doesn't like for me to drive it like that!
The two SS cars (mule and real one) don't count since they are essentially prototypes.
The 1956 SR1 production cars were fully equiped, 2900+lb cars. The SR2 cars for 57 got a longer, thus heavier, nose. Without tops and windshields, they probably weight about the same as a production 57 car, but that longer, heavier nose kind of cancels out any weight savings.
So, from my observations, the only shot that Corvette ever had at a lightweight EARLY car (I DID NOT say Gran Sport) was the 56 Sebring prepared cars.
I know how my 56 runs with a healthy SB400. I cannot imagine how a stripped down Sebring car would run with a factory perpared big cube engine. John's SR2, with a professionally built ALL ALUM FI 350 is just incredible. That same engine in the Sebring car would just be pure terror!
And, once again, let me reitterate, the 56 Sebring cars and the 56 SR1 cars ARE NOT the same cars. Yes, they have some similar appearances, mainly that big rear air scoop for the rear brakes. But the scoops are even different.
Tom Parsons
