RIVITING TOOL Chrome door pillars 1960
Hi Guys
What kind of tool is available to install the small rivets in the chrome door pillar.There are 4 rivets used to hold in the window slide channel.ThanksBob W
You could PM Mike Coletta (61retro) to see what he used on mine. He installed my window channels and door fuzzies on the '61 and they are prefect...
I use a small anvil that I made from an old 3/8" socket drive extension. Grind the end flat, and put it in a vise. Put the rivet in from the fuzzy side, set it on the "anvil", and peen it over with a small ballpeen hammer. A screw goes in the top (not a rivet), so that you can remove/install the rubber stop. The next one down is a flat head aluminum rivet. The third one is a screw also, and the bottom is a rivet (You can actually use a pop rivet for the bottom one. So...... It goes from the top....screw, rivet, screw, rivet. Good luck.
Mike Coletta
Mike Coletta
Thanks Guys.For all the information
61 Retro .Mike i sent you a private e mail.Bob W
