C1 dash insert question
Old Dec 22, 2009 | 11:59 AM
Marks69BB's Avatar
Marks69BB
Default C1 dash insert question
Just removed the dash insert assembly behind the grab bar to replace the aluminum insert and have a qusetion. What are the two threaded nuts spot welded on the inside of the backplate used for? There was nothing attached to mine.
Old Dec 22, 2009 | 12:16 PM
rustylugnuts's Avatar
rustylugnuts
Try this link: http://www.corvettepartsblog.com/53-...m-dash-insert/
rustylugnuts
Old Dec 22, 2009 | 12:25 PM
mike coletta's Avatar
mike coletta
They are for two short 1/4" X 20 bolts. I don't thing anybody EVER puts them back in. You really don't need them . Just use the three studs on the back, and it should be fine.
Mike Coletta
Old Dec 22, 2009 | 12:58 PM
Marks69BB's Avatar
Marks69BB
Thanks guys!
Getting everything ready for the windsheild/dash pad replacement and this is one of the first things I'll need ready to go back in.
Old Dec 22, 2009 | 04:10 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
some comments on the insert....when you put it back together with epoxy you have to be careful to get enough to hold it but not so much that it makes it nearly impossible to get apart. I used too much when I put it together an upon installation of the insert back into the dash I marred a corner of it. It bothered me so I took it out and replaced it again. AGHHHH, nearly messed up the stainless that goes on the edge because I had used too much 2 part epoxy. Word of warning there.
Second when you put the bezels over the ends of the grab bar, you want to make sure that you have the insert properly positioned. When you push the bezels out to the ends, if it isn't sitting right those bezels can easily marr the surface (see my note above about marred insert and taking it back aaprt, this was how I did that).
That was my learning experience on the insert.....good luck!
Old Dec 22, 2009 | 05:15 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Well - this is how much epoxy I used...can't say if its too much or not...
The epoxy sure can't be any harder to remove than grinding off the spot welds used for the original attachment points..
Old Dec 22, 2009 | 05:38 PM
mike coletta
HOLY SMOKES FRANK!!!! You won't have to worry about that coming apart!!
BTW.....nice screwdriver in the foreground. Is that a "snap-on".???? LOL
Mike Coletta
Old Dec 22, 2009 | 05:50 PM
Frankie the Fink
Army
Don't "dis" that old screwdriver Mike. That has mixed more fiberglass, bondo, JB-Weld and two part epoxy over the years than I can remember...probably 100 pounds or more. I'm passing it on to my heirs...
Besides I remember you bragging about your ancient Binks paint sprayer...
Old Dec 22, 2009 | 06:34 PM
firstgear's Avatar
firstgear
St. Jude Donor '15
the problem is that the epoxy will get into the cracks and crevices......and if you ever try to get it apart, it isn't as easy as grinding the welds off, that was easy. When the epoxy gets into the crevices the stainless trim will want to bend because the epoxy doesn't want to give up......I should have mentioned that little detail, the crap flows into places the weld never did....
firstgear's Avatar
firstgear
St. Jude Donor '15
ever!!!!!!
Old Dec 22, 2009 | 07:52 PM
Ironcross's Avatar
Ironcross
When you go to purchase a new dash, the best deal is not always the best deal.....they are 'NOT' all the same....
Old Dec 22, 2009 | 08:01 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
hmmmm.... considering all the successes i've had with it, i think Ultra Black RTV might be a good alternative way of attaching the molding...
Bill
Old Dec 22, 2009 | 09:13 PM
firstgear's Avatar
firstgear
St. Jude Donor '15
Bill
might be if it doesn't flow into the crevices....if you never need to take it apart, it isn't a big deal. My first one went together real nicely, but taking it apart was a bear, I even used high temperature to overcome the epoxy, that was the only way in the end.
The least amount of adhesive is the best way IMO.
Old Dec 22, 2009 | 10:01 PM
Frankie the Fink
Army
I don't know how much that particular epoxy really 'flows' into crevices...it was pretty thick when mixed properly. Not that its keeping me up nights but I think I could get things apart if I really had to...wouldn't be fun, but I could do it..
I went a little overboard with the adhesive because the thin trim pieces had a tendency to pop up in one place once you got another place seated properly and I got sick of fighting with it.
To C1 dash insert question
