What do do with the frame...help?
Then the frame was powder coated and baked. After it came out of the oven, they ran it through the powder coating line one more time. This time they turned off the gun electrostatics and shot directly into all the corners of the frame (electrostatics has a phenomenon Faraday caging, which basically means that the powder when charged does not want to go all the way into a corner because as you get close to the corner the electrostatic forces that cause the powder paint to stick to the part to begin with will pull the paint particles to the nearest grounded part, hence long before the paint gets to the very corner it has gone to the side of the frame). When the frame is hot out of the oven and you shot powder on it, it doesn't need the electrostatics to stick because when it hits the metal it will stick because it will start to melt and flow. this makes sure that the corners are covered.
Then they took the powder guns and shot them down the inside of frame rails. Again because the frame was hot the powder stuck to the inside. Then back through the oven for one last bake cycle. That is what I did with my frame.
Powder coating is tough stuff, you can't go wrong with it!
My customers spend upwards of six figures and want their restoration to last longer than they do. It all comes down to personal preference, in the end.
Their's not a right way or wrong way when comparing paint and powder coat. Just a choice.
I had my frame dipped at Striprite. They're in Union Grove, WI. The web page isn't much.
http://striprite.net/index.htm
The building isn't much either. Dave is the owner and I think he's a one man show.
But he does GREAT work. $550 for my frame to get dipped back in early '08. I also had him do the diff crossmember.
I then had it welded and powdercoated.
Here's a few stories to read about my process on the frame.
http://www.vetteaction.com/modules/n...php?storyid=35
http://www.vetteaction.com/modules/n...php?storyid=36
http://www.vetteaction.com/modules/n...php?storyid=37
I think this might be the 3-M product I used, as it also was an amber color: http://tinyurl.com/y97jjx3
The applicator I used was an inexpensive aluminum trigger gun for an air compressor, with about 3 or 4 differently-shaped wands and a few different spray-pattern tips... the wands could even be joined together, to fashion a shape that would get deep into the areas inside the frame (I think it cost me about $40 back then, from JC Whitney).
Since I did it all myself, I know it was done the way I wanted it done.
Looking at that newly painted frame and lovely engine next to it makes wanna goo out in the garage and start doing some work on my car
