can you de-code this engine
Old Jan 12, 2010 | 06:48 PM
vettedad61's Avatar
vettedad61
Default can you de-code this engine
I am considering buying it for my 61 vette
The number on the right front of the block is F0118
the engine casting number is 3789935
the numbers on the right side back area are A1720
any help or input will be appreciated
Thanks Scott
Old Jan 12, 2010 | 07:10 PM
knight37128's Avatar
knight37128
3789935 = very late 1961 283 block
F0118 = Flint January 18th
A1720
A = January
17 = the day of the month
20 = ?????? check again This should only be a "1" as in the year (1961)
Old Jan 12, 2010 | 07:16 PM
vettedad61's Avatar
vettedad61
is it for a corvette? why late 61 if the date is jan 1961 (1st month of 1961)
It is a complete running motor, but skips need rebuild...he is asking $250.00
Old Jan 12, 2010 | 07:51 PM
jtranger's Avatar
jtranger
When was your car built? The 3756519 is the better and more popular block for that year.
Old Jan 13, 2010 | 12:57 PM
JohnZ's Avatar
JohnZ
Thanks Scott
You're missing digits on the pad stamp; there should be at least one letter (or two) after the F0118.
Check the casting date again - it should be A 17 2.
That casting number is only correct for a very late '61 (built after March or so).
Old Jan 13, 2010 | 01:29 PM
vettedad61's Avatar
vettedad61
My 61 was built May 24, 1961. it know has a 350 but want to get a close to correct engine to build factory specs over time. this engine is on craigslist and skips but complete and wants 250.00 for it. is it the right engine to do for my 61 to be close to correct?
I know it's not number matching and never will be but my 61 isn't going for NRCS either.
Old Jan 13, 2010 | 02:39 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Interesting...my '61 rolled out on May 18th...about a week before yours and has the
3756519 block. Could that make this the very week they switched off to the 'very late'
3789935 block ? The date at the rear of my block is: D271 = April 27th, 1961.
You should not have a '2' at the end of your date and absolutely not have '20'! NCRS allows a 6 month window so if its
a Jan '61 block its fine for your car PROVIDING you get the last letters off the stamp pad suffix (and they are correct for 1961; must be either: CQ, DG, CT, DJ, CR, CU or CS) and the date issue above is cleared up.
Old Jan 14, 2010 | 12:35 PM
JohnZ's Avatar
JohnZ
I should clarify what I meant. He indicated that there was a "20" at the end of the casting date, and most likely what he saw was a "2" followed by a screw-head impression, not a "0". In any case, that's after his car was built, and would get a 175-point deduction.
To can you de-code this engine
