Transmission help
Transmission help
Can someone please help me identify two 4 speed transmissions that I have. I am including all of the numbers that I could get off of them.
Thanks in advance
1) Borg Warner T-10
T-10 IC
K 17
107 B
4-22-60 m
2) Muncie
3925660
12630
P9T28B
CT9
3950306
3857584
426811
Thanks in advance
1) Borg Warner T-10
T-10 IC
K 17
107 B
4-22-60 m
2) Muncie
3925660
12630
P9T28B
CT9
3950306
3857584
426811
Received 1,859 Likes
1. The T10-1C main case (aluminum) was used on '61-'62 Corvettes. What's stamped on the machined surface just aft of the side cover, near the top? That code will show when it was assembled.
2. The Muncie is an M-21 made on 12/28/68, for a '69 model year application. Does it have a VIN derivative stamped on the driver's side vertical rib at the rear of the main case?
transmissions
Thanks John for the help. I will look in the areas that you mentioned and repost. The tailshaft housing on the T 10 shows 4-22-60 so it might be for a 61. Should there be a VIN stamped on it also?
Jay
Jay
