steering column upgrade
Old Jan 16, 2010 | 01:27 PM
vt65's Avatar
vt65
Default steering column upgrade
Did a search, nothing there, has anyone been able to purchase a collapsible intermediate shaft for a steering column that will work on a '65 Vet? I would like to be able to get one for my own piece of mind. Unfortunately there are not that many '67 columns to be had, will C3's work? Will be adding a Burgeson PS box and this would be a good time to get one
Old Jan 16, 2010 | 04:47 PM
Larry Bittner's Avatar
Larry Bittner
Flaming River with tilt and elimantes all the junk turn signals parts. A terrific upgrade.
Old Jan 17, 2010 | 04:55 PM
JohnZ's Avatar
JohnZ
Nobody makes a retrofit collapsible steering column that I'm aware of, most likely because of the potential liability issues. The only viable approach is a '67 column (along with the pedal support, intermediate bracket, capsule bracket, and wiring changes to accommodate the '67 turn signal switch and hazard flasher switch).
Old Jan 17, 2010 | 05:15 PM
vt65's Avatar
vt65
ok thanks, just thought that it would be a good time to do it all but sourcing the 67 column and related parts may be a problem up here in the frozen north ...
Old Jan 17, 2010 | 10:32 PM
out2kayak's Avatar
out2kayak
Yea, I looked around too for the same question and came up with nothing.
I'm rather surprised that Flaming River and other vendors don't have to (due to government regulations) have collapsible steering columns.
Old Jan 17, 2010 | 10:40 PM
67*427's Avatar
67*427
I'm not sure of the differences between the '67 and the '68 column but I know there are some subtle ones. Maybe slight enough that a '68 column would work in your car, which would expand the possibilities a bit.
If just the center shaft is what you want, I believe Borgeson makes collapsible shafts that you can spline for your application. Might be worth a look.
Steve
Old Jan 18, 2010 | 05:55 AM
vt65's Avatar
vt65
Steve
yes, i will ask them when i order my new steering box today
Old Jan 18, 2010 | 07:34 AM
67*427's Avatar
67*427
If you are ordering your box from Borgeson, there are less expensive places... like Summit.
Old Jan 18, 2010 | 08:36 AM
vt65's Avatar
vt65
thanks for the heads up
Old Jan 18, 2010 | 09:19 AM
67*427's Avatar
67*427
They are a licensed dealer for Borgeson and Borgeson themselves told me about their dealers. I called Borgeson for a lot of technical questions and they were VERY helpful and responsive. I ordered the box and rag joint from Summit (rag backordered) and I'm waiting for the PS pump pulley and alternator pulley from Willcox. Should be shipped this week and then I THINK I have everything except the rag. Actually I should probably say "I have enough parts to get started and find out what I don't have".<grin>
Good luck and please, let us know what you do for your column. BTW, PM me if you want to see how I rebuilt my '67 column. Might help you some.
Steve
To steering column upgrade
