Hardtop Squeaks!
Old Jan 20, 2010 | 04:38 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Default Hardtop Squeaks!
How do you stop the all the noise from the hardtop! Squeaks and rattles and snaps and pops!!! It's driving me nuts.
Old Jan 20, 2010 | 04:57 PM
1coolC2's Avatar
1coolC2
Take it off
Old Jan 20, 2010 | 05:14 PM
Sky65's Avatar
Sky65
Hey Jeff.
Do you still have yours on?
If it wasn't so friggin cold I would take it off.
Old Jan 20, 2010 | 05:21 PM
vt65's Avatar
vt65
install earplugs! turn the radio up! get sidepipes!
Old Jan 20, 2010 | 05:38 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
He has sidepipes. And they aren't quiet.
Tom: You gotta cinch those bolts up. If you want I can come up and sit my fat *** on the top while you bolt it down in the back. Bet it doesn't rattle then.
Rich
Old Jan 20, 2010 | 05:50 PM
Sky65's Avatar
Sky65
Rich
I've already tightened the rear bolts up so much the deck lid doesn't line up with the body anymore. If I do anymore I'm afraid the rear camber will change.
Old Jan 20, 2010 | 05:53 PM
Sxrxrnr's Avatar
Sxrxrnr
WD'40 everything. Probably better double check on if likely damage to your paint, but I doubt it. You'll be amazed.
Old Jan 20, 2010 | 05:58 PM
Sky65's Avatar
Sky65
WD40 the seal against the body/paint as well?
Old Jan 20, 2010 | 06:02 PM
Stan's Customs's Avatar
Stan's Customs
Maybe install a SR III frame so the body wont flex so much...
...sorry just had a senior moment, it'll pass.
Old Jan 20, 2010 | 06:05 PM
Sky65's Avatar
Sky65
I like it! Good solution but there's nothing in my wallet but moths......
Old Jan 20, 2010 | 06:44 PM
Sxrxrnr's Avatar
Sxrxrnr
Yes, but paying attention to my caveat on potential paint damage. Probably would make things a bit better as we know what the non lubricated rubber already does to the paint. Also with WD 40 as it is a lubricant and dust magnet that goes with this, you gotta keep it clean.
Old Jan 20, 2010 | 07:22 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i suggest you get one of the vinyl strips that go between the rubber and the decklid. this will prevent the rubber from wearing your paint.
Bill
Old Jan 20, 2010 | 10:35 PM
StingU2's Avatar
StingU2
Buy a Coupe!
Old Jan 21, 2010 | 12:02 AM
57AIRBOX's Avatar
57AIRBOX
Try some Trident pure silicon grease. Wipe it on then rub it off real good, enough will remain to do the job. Once/twice a year. Charley
Old Jan 21, 2010 | 11:27 AM
sub006's Avatar
sub006
Do what used car dealers have always done on a demo drive, crank up the radio!
My car doesn't have one, hee-hee.
Old Jan 21, 2010 | 07:40 PM
1coolC2's Avatar
1coolC2
Hey Jeff.
Yup, still on there. I found that mine made the rear deck lid latches rattle and squeak, I lubed them with white litho and tadaa..no more noise, well.....at least not from the latches. You may also want to check the clearances on the alignment wedges, you can tighten down on the gap by added shims. In the end, I don’t think you can get all of the noise out....it's much like trying to have a watertight C2
You should take Rich up on his offer....I used his fat *** to hold down my top while I tightened the bolts
Old Jan 22, 2010 | 05:59 PM
Sky65's Avatar
Sky65
Buying a coupe would solve the problem and I really like the look of a coupe but the granddaughters love riding with the top down I guess I'm have to deal with the noise.
I don't think I'm ready flor that yet!
Old Aug 2, 2014 | 08:15 PM
metturq91's Avatar
metturq91
1st Gear
Default rear deck lid latches rattle and squeak
"...lubed them..." ? The rear window latches? The weatherstrip? The removable top? Or all the above?
Thanks.
Old Aug 2, 2014 | 08:30 PM
Stan's Customs
4 1/2 year old thread...
To Hardtop Squeaks!
