engine block identification
Old Jan 22, 2010 | 10:05 PM
rowingone's Avatar
rowingone
Default engine block identification
I have a 327 gm block 3782870 date code K143 and on the vin pad it has chev v8 and then F1115R although that last part is hard to read. Can anyone help me determine if this is a corvette block or what type of car it came from . thanks!
Old Jan 22, 2010 | 10:43 PM
5thvet's Avatar
5thvet
Look a little closer and see if you can see another letter after the R llike RC, RD, RE or RF.
Old Jan 22, 2010 | 10:51 PM
Panama 58's Avatar
Panama 58
327 full size, manual trans.
Panama 58
Old Jan 22, 2010 | 11:07 PM
rowingone's Avatar
rowingone
thanks guys . . where is the best resource for engine codes?
Old Jan 22, 2010 | 11:10 PM
5thvet's Avatar
5thvet
http://rowleycorvette.com/vettestats.html
This is pretty good for corvettes free.
This one includes all chevy engine codes
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old Jan 22, 2010 | 11:23 PM
knight37128's Avatar
knight37128
This is pretty good for free.
This one is much better
http://www.teufert.net/sbchevy/sbchevy.htm
P.S. They are all free.
Old Jan 22, 2010 | 11:48 PM
rowingone's Avatar
rowingone
The "R" code indicates a 1962 full size manual trans but the date code on the block is K143 . . ??
Old Jan 23, 2010 | 01:22 AM
knight37128
I think if you look closer at the "5R" you will see something else.
If not then it could be an industrial application.
Old Jan 23, 2010 | 07:03 PM
oldskydog's Avatar
oldskydog
The "R" suffix code was also used in 64 full size 250hp 327 with MT. "S" for PG.
Old Jan 24, 2010 | 03:01 PM
rowingone's Avatar
rowingone
I took paint cleaner to the pad . . and above the F code is "strickland" and below that "chev v8" - just a generic engine rebuilder or does anyone have a clue?
Old Jan 28, 2010 | 06:22 PM
rowingone's Avatar
rowingone
any help?
Old Jan 29, 2010 | 01:57 PM
JohnZ's Avatar
JohnZ
any help?
The "R" suffix was used in 1964 for the 327/250hp engine with a manual transmission in full-size passenger cars, and that one was cast in November, 1963 for 1964 production.
It's not out of a Corvette - all Corvette engines had 2-character suffixes, and the VIN derivative was stamped on the pad. Passenger car base engines didn't have the VIN stamped on the pad.
The other stampings are from a rebuilder or a creative owner.
To engine block identification
