Alignment problem
Old Jan 23, 2010 | 10:36 AM
purpledog's Avatar
purpledog
4th Gear
Default Alignment problem
I'm new to the forum and would like to ask if anyone can help me with a front end alignment issue with my '59. This car will be a dedicated vintage race car and is finished except for setup. In setting front alignment I find that, even with the adjusters pulling the upper spindle supports as far back as possible, I can only get 2 degrees of positive caster on the left side and 1.3 degrees on the right side. Camber can go to 1.2 degrees negative on the left, but only .5 negative on the right side. I would like to have at least 3-4 degrees of caster and 1-1.5 degrees negative camber.
All bushings and shafts are new and bearings are adjusted properly. The factory shim is installed between the frame and suspension support. Anybody know of a way I can get some more positive caster and negative camber?
Old Jan 23, 2010 | 01:27 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
To get more negative camber, consider relocating the lower control arm inner pivot more outboard.
For additional caster, I'd add a second shim between the crossmember and the frame.
Some vintage racing organizations frown on changes to suspension geometry. You might want to check the rules before you seriously consider either of my suggestions.
Got any pictures of your vintage racer you can post?
Jim
Old Jan 23, 2010 | 02:08 PM
purpledog's Avatar
purpledog
4th Gear
Thanks for your reply. I'm going to order some of the tapered shims and see if that gets the caster in line. The front end is just slightly too low now, so the extra shim should help that somewhat. Also looks like I may have to re-shim the radiator support.
I looked at moving the lower control arm outboard as you suggested, and it appears that it wouldn't be too difficult. However, you are correct, moving suspension pickup points is usually not allowed in production cars by most vintage racing associations.
I may go on Monday and see if I can get a new upper-outer shaft machined that has a bigger eccentric in it so I can get more camber adjustment. Any other suggestions are welcome.
I have no pictures yet since the car has been finished for only about a week. When I get this alignment issue solved I'll get it outside and shoot some pictures.
Old Jan 23, 2010 | 03:09 PM
mashinter's Avatar
mashinter
I biased my upper control arm as far rearward as possible. Because the mounting shaft moves inboard toward the rear of the car, I got more negative camber and a lot more caster.
Old Jan 23, 2010 | 04:32 PM
66since71's Avatar
66since71
Moog makes an offset upper control arm shaft that will give you some more adjustment too. It is a collision repair part that is sold by the Corvette vendors as a "trick part" ($). Let me know if you need a Moog part number.
Sounds like you might be running the Gulstrand metal control arm bushings? They will work just fine with the Moog part (did it on my 69 race car)
Harry
EDIT: I see Bill's photo and realize its a C-1... sorry for the distraction...
Old Jan 23, 2010 | 08:16 PM
purpledog's Avatar
purpledog
4th Gear
Why didn't I think of that! I'll move the upper arms back and see if that solves my problem. Thanks for the advice.
Old Jan 24, 2010 | 08:27 AM
jim lockwood
This is clever. How did you do that? Are there any issues with the spindle support binding on either control arm as it approaches the limits of travel? Got pictures?
Jim
Old Jan 24, 2010 | 12:03 PM
mashinter's Avatar
mashinter
Jim
Jim:
I did this in 1977, so I am assuming I bottomed the forward nut on the shaft and then backed it out just enough to fully engage the control arm as I threaded it into the arm?
I'm sure I ran the suspension through its travel without the spring installed to check for binding (I always do this).
Here's a current picture. Excuse the condition. The car's been sitting for decades (restoration in the planning stage).
Bill
Old Jan 25, 2010 | 12:41 PM
purpledog's Avatar
purpledog
4th Gear
I re-indexed the upper arms as far back as I could. This is easy to accomplish by removing the bushings, moving the arm back, and re-starting the bushings into the arm and shaft in the new location. After doing this I am getting 2.5 degrees of caster and 1.2 degrees of negative camber on both sides. Still not enough caster, so I have ordered a couple of the shims. Hope that works.
Old Jan 26, 2010 | 06:52 AM
mashinter's Avatar
mashinter
I have a note (from 30 years ago) that I was getting about 1 degree of negative camber and about 2 degrees of caster.
I remember my car (see pic. above) had a strong tendency to go to full lock when backing up. I had to hold the wheel firmly to keep the front wheels pointed straight ahead. Not sure what is causing that (KPI?)...2 degrees of caster is not a lot.
Old Jan 26, 2010 | 08:18 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Years ago, the owner of the alignment shop that I use (THE ONLY ONE IN OKLA CITY I TRUST!!!) taught me a little trick to gain (or loose) caster.
On the LOWER- INNER shafts, loosen all 4 bolts. Add alignment shims under the REAR of the shaft. Tighten bolts. TOOOOOOOOO EASY to add caster by this method. We did this to the 56. I don't have any pictures of this, but if anyone wants to see, I can take pictures tonight.
Tom Parsons
To Alignment problem
