Installing my rear valance on my 65 Coupe and where it attaches at the bottom to the rear quarters there is about a 1/8 to 3/16 gap. Should there be something between?? Gasket or sealer?? Dont want to force things. Thanks Dave
Nope, nothing at all.
They just touch each other and the bolt/nut holds them together.
Our 67 had nothing there when taken off or new one placed on. Are you replacing with a new one? If so, (I found out) be prepared for possible small to large gap and contour issues.
At the bottom corners, there is supposed to be a slight gap. In fact, a thin shim goes between the valence and quarter panel.
That's correct - although you never see them any more, shims were released on an "as required" basis to make that gap appear parallel if the body was a bit wider than the valance panel; they're shown in the Assembly Manual.
Mine never had shims and as was said maybe it was a option if the body didn't align good enough.
I have had my '65 since August 24, 1967 and am the second owner.
There were no shims on mine but then again mine seem to align properly too.
Peace.
