From: The problem is all inside your head she said to me.
Rally ID help.
396 Rat Do theses sound like the identifing numbers. This is from left to right with the first four on the left of the valve stem. I only checked one of each so the other two could be different but I would have to check.
Front(15X7)- K L 5 M 6 FW
Rear(15x8)- K L 1 12 9 AZ
What are they? Thanks
Edit ---Yes I was not sure if the "L" was an L or a 1.
The "FW" is the identifier for a '65 15x7 Corvette ralley wheel. "K" is for Kelsey Hayes, the "L" is actually a "1", I believe, "5" is for 65, "M" is probably March and "6" is the sixth of March.
"AZ" is the identifier for a 15x8 Corvette wheel, probably the "1 12 9" means Dec 9th of 1971
... but I'm not sure when/if they changed the month from a letter to a number.
There may be more numbers/letters on the back of the wheels. In any event, they seem to be of differing heritage.
Of course there were no '65 rally wheels. The "FW" wheel is a 71-77 Chevelle and Monte Carlo 15 X 7 rally wheel. It looks very similar to the 1968 Corvette 15 X 7 "AG" wheel -- except for wheel offset.
