Vent window service
Old Jan 28, 2010 | 07:33 PM
raypilot65's Avatar
raypilot65
Default Vent window service
Has anyone recently sent their vent windows out for repair? On one side of my 65 Convertible I need a new pivot hinge attached and on the other side I need a new t-bar that goes in the regulator. Hoping that someone has recently had this done and can recomend a source. Please add what it cost too for comparison. Thanks!
Old Jan 28, 2010 | 07:50 PM
fullcontrol's Avatar
fullcontrol
Paid Senior Member
Call Dick at Virginia Vettes.
Old Jan 28, 2010 | 07:55 PM
raypilot65's Avatar
raypilot65
OK! thanks! Anyone else have this done lately?
Old Jan 28, 2010 | 08:07 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Old Jan 29, 2010 | 06:27 AM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
Virginia Vettes can put on new pivot pins and replace the broken T with a new one and polish the frame so the repair is not seen
1-757-229-0011
Old Jan 29, 2010 | 08:32 AM
raypilot65's Avatar
raypilot65
1-757-229-0011
Thanks! I'll be calling you today!
Steve
Old Jan 29, 2010 | 05:27 PM
Eugenio's Avatar
Eugenio
I just had my 67 vent window pivot replace. I had it done by Paragon.
It came out to $85.00 for the work plus parts which is the cost of the pivot and the material to replace the glass back in the frame.
All in all the repair came out good. I would recommend you also send in the full frame around the vent window s/s frame. In my case the pivot did not align with the hole in the frame and I had to bend it a bit to fit. Other than that they did a good job. Turnaround is about a week.
Good Luck
Old Jan 29, 2010 | 07:12 PM
fullcontrol
Paid Senior Member
Recently found an original LH vent window frame with dated glass on ebay for $50 Buy-It-Now. Frame was in great shape, just popped the clear glass out and installed my tinted glass. After a couple minutes on the buffing wheel it was like new again.
Now I have a frame without a pin and a clear dated vent glass in my sell pile. May just break even on that one. How often does that happen?
To Vent window service
