Reinforcing a C2 frame?
Old Jan 30, 2010 | 12:44 AM
c2ray's Avatar
c2ray
Default Reinforcing a C2 frame?
I have my swc completely striped down, and a friend of mine suggested I take the frame over to a local welding shop and see if they can strengthen it. I have never heard mention of this on the forum so I am asking for opinions. The frame seems very solid to me....I have taken a hammer and "tested" all over the frame and all I hear is sharp pings of solid metal.....no dull thuds. So since I plan on restoring this as a nice driver with a mild 350/350 under the hood with a four speed, is there any reason to try and "find" a way to strengthen the frame?
Thanks.
Old Jan 30, 2010 | 01:23 AM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Thanks.
None. Since you are only using it for a driver. Not race etc..
Old Jan 30, 2010 | 04:58 AM
mechron's Avatar
mechron
Thanks.
yes there is. on your 63 frame is the body off resto. mig weld all the seams on the frame. mig in 3/8 plates in all the corners, it takes time but it will make the frame and body solid. i did it on my 64 coupe, your 63 will engoy that.'
TEX i hate you (just kidding) your 63 is a beuty, i love it..
to the OP, mig weld that frame and add 3 8 inch plates on all corners. the frame will be solid.
Old Jan 30, 2010 | 06:19 AM
groovyjay's Avatar
groovyjay
http://c3-r.com/gsrebgalindex.php
Old Jan 30, 2010 | 07:31 AM
angelob's Avatar
angelob
Another quick question for others, if the frame was plated and welded, would a car take any 'point hits' for this improvement over origionality?
Old Jan 30, 2010 | 08:05 AM
mike coletta's Avatar
mike coletta
If the frame is solid, I wouldn't do anything. You will take a hit in judging if you modify the welds or add any additonal metal to the frame.
Mike Coletta
Old Jan 30, 2010 | 08:12 AM
mechron's Avatar
mechron
WHO CARES??? if you are a NCRS guy just weld the top seams, they wont show.
good question, any NCRS guys, would a welded frame take hit in judging??
Old Jan 30, 2010 | 08:36 AM
mike coletta
If they can see it, you'll get a hit. I don't get what the point is in welding the seams solid??? The plates in the corners make some sense from a rigidity standpoint, but you'll for sure take a hit on that.
Mike Coletta
Old Jan 30, 2010 | 08:49 AM
redvetracr's Avatar
redvetracr
Buy an older copy of the Chevy Power book it has a chapter on setting up a Corvette for racing (available on ebay but ask about the Corvette chapter BEFORE you buy, the newer versions don`t contain what you need).....they go into detail on strengthening a frame. If your a NCRS "purist" don`t bother, just weld up that top seam....
Old Jan 30, 2010 | 11:40 AM
mechron's Avatar
mechron
Mike Coletta
mike, it will make a race car more solid. i do mig weld all C2 frames and add brackets in all corners i don,t care about NCRS i like a car drives fast over a bunch of NCRS guys snooping around my car.
Old Jan 30, 2010 | 01:12 PM
Sam Kalmuk's Avatar
Sam Kalmuk
2022 C2 of the Year Finalist - Modified
C2 of Year Finalist (track prepared) 2019
2017 C2 of Year Finalist
2015 C2 of Year Finalist
Originally Posted by groovyjay
Jay: That is a great example of what to do to the frame. It is over 40 years old.
There also are a few Pics of the GS inside the boxes.... Keep us updated on
the progress of your build.....Sam
Old Jan 30, 2010 | 01:22 PM
MiguelsC2's Avatar
MiguelsC2
Thanks for the compliment.
Old Jan 30, 2010 | 01:26 PM
GCD1962's Avatar
GCD1962
Tell your friend to put the beer down. It is a waste of time and money to do this on a driver such as you have. Of course, something can always be made to be stronger or better, but in this case direct your money to more meanful and beneficial things.
Old Jan 30, 2010 | 01:37 PM
MiguelsC2's Avatar
MiguelsC2
Old Jan 30, 2010 | 02:37 PM
JohnZ's Avatar
JohnZ
The entire frame and numbers are only allocated 15 points, so additional welding would only get a one or two-point deduction (out of 4500 for the whole car); washers that don't squirt or a lighter that doesn't "pop" get a 25-point hit.
Old Jan 30, 2010 | 02:47 PM
mechron's Avatar
mechron
John Z, good to know. i'll just keep mig welding up C2 frames up and take those few points hits...
Old Jan 30, 2010 | 03:29 PM
Vogie's Avatar
Vogie
Additional recommendations in the manual are to box the front frame horns to make the sway bar more responsive (didn't do this), weld a plate over the opening at the steering box (didn't do this) and to gusset the lower A-Arm mounting brackets (did this). I have boxed the motor mount horns and installed the Tom's gussets at the differential mounts as well to handle extra horsepower and drag strip runs. Both frames I have acquired that had been run on the strip had the differential mounts repaired.
To Reinforcing a C2 frame?
Old Jan 30, 2010 | 03:34 PM
MiguelsC2's Avatar
MiguelsC2
Did anybody notice the guy just wanted a daily driver. Not a road or drag race car.
Old Jan 30, 2010 | 04:25 PM
silverslashstreak's Avatar
silverslashstreak
I just finished restoring a 63 roadster to be used as a driver. I welded all the seams and reinforced most of the weak areas. I have been driving C2 and c3s for 40 years, some new and some high mileage, this car with the welded frame is absolutely the best driving C2-3 I have ever driven.
Pulling the body off my SWC and welding the frame is one of my next projects.
If you have the body off, I would not put it back on till I welded the frame up.
Jeff
Old Jan 30, 2010 | 05:39 PM
GCD1962's Avatar
GCD1962
Jeff
While I don't dispute that's what you sense, I still don't buy it for a driver. If indeed the frame was "flexing" at some points, over time stress would develop cracks. How did you know what the "weak:" areas were? If some cracks were there I would agree, but without any cracks how could you tell?. You have to consider the fact too that some items made of steel are designed to have some flex. Although undetectable it could be present. If you stiffen these areas it makes some points too rigid which could lead to cracks developing in other areas. I drove my '62 for years and years with a weak frame (when I took the body off you could flex some areas pressing down with your hand). Even driving it that way it was hardly noticeable. I changed the frame and while I could notice some improvement it was not a big one. If you are starting with a solid frame and add plates and welding I find it hard to believe one could notice any difference. Again just my opinion
