My 66 has slight fender flares on fron and rear, tires are 215 70 15. I want to put a wider tire on the rear only, without extending past the fender. My question is will I have to be concerned about the tire hitting the trailing arm or will I be okay being that the car has flares. Thanks in advance...
Depends on the size of the flares, rim width and backspacing. I ran 255/60 15 on stock C3 ralleys, 15X8 4" bs, on the 65 front and back. Stock suspension. I too have small flares. Here's a pic with the 15s. I running 17s now.
I'm from Fredericksburg, Va, about 50 miles south of the 14th street bridge. My buddy is doing a '65 coupe in F'burg, and I run up there every so often to give him a hand.
If you're somewhat close, maybe we can hookup. I'd like to check out your '65.
After asking the same question about my C2 non-flared fenders. The 215/70-15 on 6 inch rallies was the widest I could go with assurances of no conflicts. With flares, I am sure you could jump up a notch or two. Keep an eye on rear spring to wheel clearance.
BILL SR
Just drove by Fredricksburg today headed for VA Beach for work!
pm sent.
Two things you need to consider are not only tire size but wheel size and back spacing. I have a 65 coupe with stock TA. I have 225/50X17 tires on 17X8" wheels with 4 1/2" Backspacing. I have clearance but it's close. You need to consider the width of the tire sidewall and wheel size/back spacing. All comes into play.
