1960 windshield assembly
Old Feb 17, 2010 | 11:40 AM
BOB WINSKI's Avatar
BOB WINSKI
Default 1960 windshield assembly
Hi Guys,Looking for any tips on putting the windshield back together .Had the frame restored.Any help will be appreciated Last big item on the restoration.Thanks Bob W
Old Feb 17, 2010 | 11:44 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
This is one of the better articles I have seen on the topic:
http://www.masacc.org/Documents/Wind...eplacement.pdf
Old Feb 17, 2010 | 11:52 AM
BOB WINSKI's Avatar
BOB WINSKI
Frank, That will be a big help ''THANKS''Bob W
Old Feb 17, 2010 | 12:37 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
It is a fun piece! I just did this the weekend before last.
I noticed it helps to have an extra hand putting the seal onto the windshield. You really have to pull to get the top of the windshield seal onto the windshield. Make sure to measure the seal to the correct location. Also, i would suggest adding some window sealer at the bottom of the seal to prevent it from coming off when you place the windshield assembly back onto the car.
I kept the top windshield channel together then added the two side window post before placing it onto the glass. Then put the mount tabs onto the bottom windshield channel on each side. You have to have the bottom channel completely assembled before attaching it to the bottom of the windshield. In my case the bottom windshield did not have to go completely over the seal. Not sure if thats how it is suppose to go though worked for me. The line between the top fiberglass at the curved looked good when I prefitted the windshield assembly to the body.
It took some time to get it together.
That document would have helped!!!
Old Feb 17, 2010 | 12:39 PM
rengawdor's Avatar
rengawdor
This web site may help as well....
http://pages.sbcglobal.net/lporopat/index.html
Rod
Old Feb 17, 2010 | 03:41 PM
BOB WINSKI's Avatar
BOB WINSKI
Thanks Guys for the other postings.Bob W
Old Dec 24, 2011 | 01:12 PM
Larry P's Avatar
Larry P
Rod
Has been moved to-----
http://www.gatewaycashregister.com/car_site.html
Old Mar 24, 2013 | 02:44 PM
6Tvette4me's Avatar
6Tvette4me
Cruising
Just signed on to search for the same info as I'm laying out all the pieces that I have had restored. Cad plated parts that don't show and chrome plated ones that do. Seals and fastenings, etc.
Old Mar 24, 2013 | 10:37 PM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
The ST-12 has a section on windshield frame assembly that is excellent.
If the posts were chrome plated test fit them to the top header stainless first as they usually need to be ground down carefully to fit properly.
One key to the final assembly steps is use soapy water and a good rubber mallet and don't be afraid to knock the frame together with the mallet.
Old Mar 25, 2013 | 07:43 AM
Frankie the Fink
Army
The ST-12 has a walk-thru but it doesn't have HD color photos nor tips on how to deal with some of the problems with newer repro parts - like the rubber you get now.
BTW - I would check Corvette Rubber first and buy all the soft parts from them:
https://www.corvette-rubber.com/mm5/...ory_Code=5WATC
To 1960 windshield assembly
