pilot bushing help
Old Feb 28, 2010 | 01:06 PM
1Redctoo's Avatar
1Redctoo
Default pilot bushing help
I just finished pounding a brass pilot bushing into my crank . It had to sit in the freezer overnight to get it in and now it won't budge further and has about an 1/8 in to go until flush with the crank . Is it in far enough ?
Old Feb 28, 2010 | 01:15 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Flush with what part of the crank? Is the bushing bottomed out in the hole? Post a photo if you can.
Old Feb 28, 2010 | 01:37 PM
1Redctoo's Avatar
1Redctoo
I think it should be flush with the edge of the hole in the crank ,but it sits up about 1/8 inch . There seems to be a little more depth left in the hole but the bushing won't move now and is beginning to distort .
Old Feb 28, 2010 | 01:43 PM
magicv8's Avatar
magicv8
IMO the only way to be positive, is to mount the bellhousing and measure the distance to the transmission's mounting face, which you can compare to the distance from the face of the transmission to the input shaft bushing surface.
Old Feb 28, 2010 | 02:21 PM
MikeM's Avatar
MikeM
It shouldn't be that hard to install anyway. Stick an input shaft in it and see if it will still slide in the pilot.
Old Feb 28, 2010 | 03:10 PM
1Redctoo's Avatar
1Redctoo
looks like I have about 5/8 in and the shaft will only go in about 5/16 so it looks like it will fit . If anything the bushing might be IN too far .
Old Feb 28, 2010 | 07:46 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I take it you didn't measure it against the old one for width and depth? I never had to freeze one and they went it fairly easy on an old input shaft. You better be sure before you put it all together.
Old Feb 28, 2010 | 08:00 PM
midyearvette's Avatar
midyearvette
listen to kermie!.....
Old Feb 28, 2010 | 08:31 PM
Glasshole's Avatar
Glasshole
My pilot bushing is flat flush with the end of the crank. Don't think it should be sticking out at all.
Bob
Old Feb 28, 2010 | 08:53 PM
Nitrodamus's Avatar
Nitrodamus
That definitely isn't right... no freezing or pounding necessary, plus if it is distorted it is no longer a bushing.
Old Feb 28, 2010 | 09:00 PM
65specialk's Avatar
65specialk
If the bushing is not deep enough you could l break the ears off your trans when bolting up. Sonnds like something is not correct.
Old Feb 28, 2010 | 09:19 PM
mikem350's Avatar
mikem350
Also check the archives for which bushings get grease.... some don't depending on what they are made of!
Old Feb 28, 2010 | 11:07 PM
6t5silver's Avatar
6t5silver
You could tap the pilot bushing with a 5/8 nc tap and jack it out with a bolt. See what the problem is . Chances are the pilot bearing has collapsed. Try the tranny input shaft in the bushing to see if its damaged.
Old Mar 1, 2010 | 12:57 AM
Sxrxrnr's Avatar
Sxrxrnr
Where did you get this bushing and what is the part number? Perhaps is the wrong one for your crank. An ill fitment can cause a wide range of problems from unexplainable drive line vibrations to clutch chatter to damaging front transmission main shaft gear bearing, to gear clashing when shifting. I think that i would likely start over before moving forward with buttoning it up.
Old Mar 1, 2010 | 02:40 AM
67L36Driver's Avatar
67L36Driver
More like a 5/8"-18 tpi fine thread.
Bushing bore is way too big for 11 tpi. Closer to tap drill size for 18 tpi. More thread engagement.
Old Mar 1, 2010 | 06:58 AM
ejboyd5's Avatar
ejboyd5
1) You shouldn't have to pound it in
2) It should be flush with the end of the crankshaft
3) If it has begun to distort it is already toast. Take it out and start over with the correct part.
Old Mar 1, 2010 | 07:05 AM
CJS's Avatar
CJS
If your engine was a PG originally, the bushing hole was not reamed at the factory and so that causes a really tight fit that usually will not work. You need a custom size OD bushing.
To pilot bushing help
Old Mar 1, 2010 | 08:52 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
My bet is with CJS's diagnosis....
Having to freeze a bushing and then pounding it in is certainly not normal.....
Old Mar 1, 2010 | 09:07 AM
Kerrmudgeon
You should take it out and check it anyway. Use the old mechanics trick of packing the hole with heavy grease (wheel bearing) and using an old input shaft or anything of same diameter, start tapping it into the hole, put in more grease as you need it, and amazingly the grease pushes out the bushing. Then get the right one!
Old Mar 1, 2010 | 10:38 AM
64tux's Avatar
64tux
i think you have the wrong pilot bearing! should be flush and not that hard to put in! pretty important that its right!!!
