I've been reading recently about the lexus problems with unintended acceleration and also listened to the youtube 911 call which is down right scary. also after having my sisters Lexus in the shop for three weeks after it went from 80 mph, to suddenly unable to go above 30 mph on the highway, with no real explanation from them, made me a bit concerned when I was attaching my ground strap to the accelerator linkage. I noticed that it affects the motion of the linkage. Should the spring break the carb would be left in the open position. Perhaps this would happen if it were not attached but I didn't remove it yet to try.
My questions:
Have others noted this interference or is it a routing issue.
Would anyone have a picture of the correct orientation?
Have others installed a secondary spring of some sort?
also, I'd like to know what type of bolt and washer is used at this point.
i would not worry about the ground strap giving you any of the problems associated with the recent throttle problems with the radio controlled linkages of today....im sure that someone at sometime has experienced a broken throttle spring but i have not, ever....mechanical linkage is really fool proof save for the spring and a broken motor mount on the driver's side...jmo...
I have power nothing on my '62, just turn the key off.
That being noted, just move the linkage through its full travel and see if it binds or sticks anywhere. I did have the linkage binding a bit on the shielding at one point on mine, some tweaking and it was fine.
I had a runaway accelerator experience in the '61 two months after owning it. (dual quad car). The tach (this was before it was calibrated so who knows the actual RPM) buried but it was a simple matter to switch off the key. Never did find the cause but suspect ignition shielding. I rearranged the linkage and no problem since. Scared the bejesus out of me.
This is one of the smartest moves any of us can make to help prevent throttle return problems:
Originally Posted by 62Jeff
Double springs:
When I first got my '64, I replaced a Bubba spring with a "correct" spring from one of the Corvette parts suppliers. It did not have enough tension to return the throttle even without a ground strap on the linkage. I decided to install dual springs like Jeff's for some peace of mind.
had a stuck accel rod on my zz4 in the 66. my dumbass fault. the
air cleaner bottom did not like me and grabbed the rod. i never thought
my right foot could move that quick and stomp. let go just as i was reaching for the key. i know that would not of helped that much. jim
...The tach (this was before it was calibrated so who knows the actual RPM) buried but it was a simple matter to switch off the key.
Frank I had a similar experience when I first finished my 62 - in my case it was a mechanical failure (secondary butterflies off-set in their bore just enough to jamb when opened fully).
Not wanting to turn off the key at 5,000 RPMs, I just rode the brakes really hard until I could get the engine RPMs down, and then turned off the key.
I like dual springs though because I don't want to have to trust that in a panic I'll remember to shut off the car.
I just went through replacing all the linkage in my '65. My car was originally a 300 HP and after pulling the original motor I replaced it with a "mule" 327 built up like a 365 HP version. This was done 2 years ago.
Long story short, was chasing why my secondaries were not opening and it was suggested that either the carpet padding and carpet were preventing full travel of the linkage under your foot or there was some slipping going on where the accelerator linkage passes through the trans tunnel and hooks to the arm which holds the rod at the carb (hope I'm clear on my descr here, LOL!).
Initially I had thought it was just an adjustment at the rod. Made some tweaks there and took it out for a spin. Went through the gears on 16 mile road and experienced some GREAT power shifting 1st to 2nd to 3rd...holy mackerel!! Well it was time to get out of it and that's when I realized (at about 90 mph) that the front end was still up in the air, meaning she's pulling hard). Now, I didn't think a split second about shutting her off. I immediately shut the key off and coasted over to the side of the road. It's because I was "tuned" to this possibility or keenly aware of this happening that I did this. My '5 is a manual steering, manual brake car and you know it's quite easy when rolling to steer her around. Obviously my adjustment tweaking the rod wasn't getting it.
I ended up replacing all of the 45 year old linkage along with a correct for a 365 HP rod.
You really have to pay attention to the total travel of this linkage to assure yourself there is no binding...anywhere.
The ground strap should be a non issue in binding. Just make sure you have enough "copper ribbon" on that strap to allow for travel. Oh, right or wrong, I attached the copper strap to the inside of the arm.
Here's some pics, one of the old linkage and the installed after setup.
Regards,
Jim
In God We Trust!
ps In the 1st directly overhead shot down on the motor, you'll notice how straight front to rear of the motor the accelerator rod is. Just another point of reference to assure yourself that there is no binding building up at the connection points of the rod.
Jim, the accelerator rod in the photos is installed backwards - the end with the threaded swivel goes at the rear, to the accelerator lever (with the swivel on the inboard side), and the bent end goes at the carb lever end, with the flange on the plastic sleeve and the hook on the return spring on the inboard side, facing the carb.
If the spring breaks, the engine would suck carb open, I believe.
Hey 62Jeff,not trying to pick on your car but you can stop those leaky intake bolts from putting oil on top of the intake. Remove one at a time and clean the bolt, I put permatex ultra copper on the threads and then thread them back in.
Yeah, did that about 2 years ago. The picture predates the repair.
I guess I trust my reactions more than most....but I've had a few runaway throttles over the years and have always just shut it off with the key. In each situation (probably 3 in a car and 1 on a motorcycle) I wasn't in imminent danger of hitting anything. I don't think putting the vehicle in neutral where the engine can redline until it blows is real smart unless there is no other choice.
I can't imagine a runaway 'fly by wire' modern car where you go through the 'shutdown drills' and nothing works! Having developed software for aviation systems for many years...EVERYthing has a failsafe that is tested, tested again and then tested once more in a simulator and then tested in real aircraft by test pilots before an ECP (Engineering Change Proposal) is ever moved into production.
If an aircraft is involved in any incident and the software is the suspected culprit ... it was late night/weekends and "asses and elbows" until it was corrected....not denials of the issue or foot dragging. Of course a dead pilot was a million dollars in lost training....a deceased motorist ? Not so much.
