Willcox New Wiper Motor Testing Video
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Jerry's drum solo is getting all kinds of hits from this post..
Former Vendor
bump
Strange.I did as in the video but with the motor on the car but the wipers work nonstop until i take the ground wire off
Willcox PM me a price for a new restored complete motor with the washer parts
Since i live in Norway there will be no old motor in return(shipping costs)
Former Vendor
Saint!
Did you ever pull the entire motor from the car and perform the bench test as outlined in the video. The last time we talked you still had not done this and you had the motor in the car.
I'd hate to send one to you and then you have the same problem.
Willcox
Willcox
No i never had it out of the car. Took the lid off and cleaned it with WD 40. Have not tryed it any after that.
But when the wiper motor run and i take off the ground terminal the wipers park where they are at the windshield the moment i disconnect the ground so there have to be something wrong i think
Former Vendor
Please remove the motor from the car.... and do the test exactly as shown in the video... I'm gonna bet it works when you do this.. Do not leave any wires attached to the motor from the car.. and hard wire it to either an extra battery or a good 12 volt power supply.
Then.. you let me know the results. I hate to say this but again.. I'm betting on the motor and I hope I'm correct!
Willcox
Willcox
Could you do a video of a C1 wiper motor test
Could you guys do a video of how to test a C1 wiper motor? Mine's a 60. Do I just ground the case, put 12v to the brown wire, and move over the switch on the case?
Thanks,
Rick
Thanks,
Rick
Former Vendor
Yes, you power up the brown wire and ground the case. Operate the motor from the slide on the front cover.
Willcox
Former Vendor
bump
missing ground
Thanks for the video and information on the site. Was able to test the my wiper motor works when you supply 12 v to center connector and both speeds when grounding the outside wires(yellow and blue).
My issue is tracking the elusive missing ground as the yellow wire on the harness shows a ground, the blue one does not. Looking at the wiring diagram, the blue is not tied to anything and since the yellow wire has a ground, assume that the switch is getting a good ground from the cluster?
The switch is new as well as the wiring harness. What are best places to start chasing this?
Also the ground wire under the dash off the radio is connected to birdcage and confirmed that ground is good. All my dash lights, clock work.
Received 1,857 Likes
#33
I tested that wiper motor was grounded, it checked out.
I disconnected the connector from the motor and checked for a ground at the light blue and yellow wire connections. The yellow wire showed a ground, the light blue did not, thus my dilemma is the switch getting good ground from cluster since yellow wire is showing a ground?
#34
A nice video to add...would be the installation of the grab bar...particularly the grueling technique required to get the chrome "end caps" up over the vinyl (and back) to install properly...
#35
one two three connector for 79 wipermotor
Great video, good education. I am tinkering with a 79 wipermotor, where the 123 connector is broken. Who knows where to get such a repair item. Any tip highly appreciated.
#36
Former Vendor
60.. you just need the connector? Or the terminals?
#37
The three terminals are inbedded in a plastik piece which is revited to the aluminum case or body of the motor. The plastic piece of that 123 Connector, as you call it in the video, is broken.
As my wiper motor is mechanically very good I'd like to drill out the connector and replace it in order to have the three terminals separated properly.
#38
Former Vendor
This piece... I'm not sure if I have any left but it really isn't hard to find one. Most motors from the 70's and early 80's used this terminal.
#39
If you have one left, would you send it in a padded envelope to Europe?
Let me know your details by PM and I would answer accordingly right away.
Thanks, appreciate your service to the forum very much. Learned a lot by your videos and other tips.
#40
Former Vendor
The noise you are hearing is a clicking noise correct:
The only way to make the motor click when the switch is turned on is for there to not be a ground present on the motor case.
When you turn on the wiper switch it grounds out the yellow and the blue wires for low speed. If your motor case is not properly grounded properly it will back feed voltage and cause the electromagnetic coil in the park switch to engage, and click.
This is the only way to make the motor do the clicking noise. I think if I were you I would run a new ground from the engine to the wiper motor and see if your issue goes away. Did you bench test the motor as in the video above to see if it functions properly?
I'll post up the newest video soon.. possibly later tonight.
