Lost fitting frustration
Old Mar 6, 2010 | 06:39 PM
vic z's Avatar
vic z
Default Lost fitting frustration
Had the cluster out to paint and change the bulbs.Well this would be a great time to change the oil line as well,(wrong)! Took out the old fitting to replace the new oil line and dropped the male brass fitting.Now you would figure it would hit the garage floor.Wrong again. I spent over 2 hours looking for that little sob with no luck. I swear if I had the engine hoist I would have pulled the motor ( just venting). I finally gave up cursing and calling it everything you can think of,like thats going to make it appear. Watch tomorrow I will find it on the garage floor,( wishful thinking). Thanks for letting me vent !!
Old Mar 6, 2010 | 06:45 PM
65hihp's Avatar
65hihp
Default been there, done that
when that has happened to me, and it happens to all of us, I walk away, and grab an adult beverage. When I go back later to resume search, I start by looking in places the part could not possibly have rolled to...
It is always right there !
Old Mar 6, 2010 | 06:53 PM
66jack's Avatar
66jack
if your splash shields are still on....look in the verry back of it....or it stuck on the shift linkage
Old Mar 6, 2010 | 07:50 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
its probably in the spot on the car that your fingers are JUST to short to touch... you know the spot.. now go look!
Old Mar 6, 2010 | 07:58 PM
bmcnitt's Avatar
bmcnitt
I always take this magnet I have on the end of a two foot flexable handle and just start moving it around. A lot of time the magnet will grab it from somewhere.
Old Mar 6, 2010 | 08:10 PM
65tripleblack's Avatar
65tripleblack
Yeah.
I just love my "special" magnet that grabs hold of brass parts.
Old Mar 6, 2010 | 08:20 PM
Gman58's Avatar
Gman58
Default Easy
Originally Posted by 65tripleblack
Yeah.
He didn't say he was using a magnet for brass parts. He just used it, you know as an example. Greg
Old Mar 6, 2010 | 08:23 PM
Gman58's Avatar
Gman58
Default Or
Maybe is was a brass magnet. Just kidding. Greg
Old Mar 6, 2010 | 08:25 PM
midyearvette's Avatar
midyearvette
i have an xtra vic if youre talking about the flare fitting thingy for the back of the oil gauge..pm me if you want me to mail it....
Old Mar 6, 2010 | 10:18 PM
bmcnitt's Avatar
bmcnitt
Rough crowd. I will have to read these things a little closer before I post in the future. Haha.
Old Mar 6, 2010 | 10:23 PM
narlee's Avatar
narlee
Just no slack.
Old Mar 7, 2010 | 12:01 AM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
What I do is take an identical piece, drop it in the same manner and watch it fall.
It should land in about the same place, right?
Does it work? Not usually.
Old Mar 7, 2010 | 06:34 AM
65tripleblack
OMG........
You must be from Joisey.
Old Mar 7, 2010 | 11:14 AM
wib1961's Avatar
wib1961
Check your pant cuff
Old Mar 7, 2010 | 01:24 PM
Kent in KC's Avatar
Kent in KC
Default Assuming you have an air compressor -
- have someone look under the car while you spray some air all around the engine compartment. It's worked for me.
Old Mar 7, 2010 | 02:54 PM
w1ctc's Avatar
w1ctc
If your really worried about the fitting landing in the place that will cause the most damage, heating the car to 940 degrees will melt the brass part. By doing so, you will never have to work on this car again.
Old Mar 7, 2010 | 03:16 PM
Texaspilot180's Avatar
Texaspilot180
This is what I do after a normal search all around, crank up the air compressor and grab the blow gun, get under neath and start shooting bursts of air into the nooks and crannies to knock it loose. From experience, wait till the compressor kicks off, then a burst of air and listen for it.. it will appear after a while.
To Lost fitting frustration
Old Mar 7, 2010 | 03:34 PM
JohnZ's Avatar
JohnZ
The inner and outer triangular splash shields are terrific "part traps"; don't ask how I know that.
Old Mar 7, 2010 | 05:01 PM
shooter1951's Avatar
shooter1951
Take off your shoes and socks and walk around the garage. Guarantee you'll step on it and probably with the pointed side up.
Old Mar 7, 2010 | 06:08 PM
4440stevesvette's Avatar
4440stevesvette
Default Lost part
Two days ago I was reinstalling the front sway bar on my '65 and I had it on upside down (yes, you can do that) so I'm taking the sway bar links apart and just laying them on the floor with the sway bay balanced on 3 boxes, those bars are heavy you know. Well I get the bar back into postion and I'm hooking up the links and lo and behold I only have 7 bushings when I KNOW I had 8 bushings just minutes ago. I backed the other two cars out of the garage, swept the floor on my hands and knees with a foxtail broom and never did find it. Next morning I had to call Paragon and order a another set of bushings. I guess the Cookie Monster must have ate it!!!
