Soft top Frame Adjustment
Old Mar 9, 2010 | 12:04 PM
irlrogue's Avatar
irlrogue
8th Gear
Default Soft top Frame Adjustment
I have a 67'. I had the frame for the top refurbished prior to installing a new vinyl cover. The refurbished top fits fine on the passenger side however the aft securing pin on the drivers side is about an inch short of the hole. Does anyone have expertise adjusting the frame.
Old Mar 9, 2010 | 12:24 PM
365GTB4's Avatar
365GTB4
You may have to bend the back bow to get it to fit. Check and see if the frame is symmetrical. Also, as I recall the pins are left and right, so check the pins. I assume the top fit before the rebuild. Also loosen the mount screws on the B-pillar and see if it tips back.
On another note;
I have been studying this leaking top problem for a while and have come to the conclusion that they leak because the canvas is installed to tight and the header bow lifts and allows water to seep across the top of the windshield. The other thing that must be done right is the round trim in the leading edge of the top must be positioned to be the first line of defense against the wind and rain. It must lay down and deflect the bulk of wind and water. The secondary seals are just that.
Old Mar 9, 2010 | 08:55 PM
JohnZ's Avatar
JohnZ
The #1 rule in any convertible top installation is to adjust the top frame and to install/adjust the seals and side glass BEFORE you install the top skin.
By "an inch short" do you mean the top bow won't go down far enough to engage the pin in the ferrule, or do you mean the pin is an inch short (fore-aft) of aligning with the hole in the ferrule?
Old Mar 10, 2010 | 09:19 PM
woodsdesign's Avatar
woodsdesign
I agree with John Z. The alignment has to be done b/4 installing the canvas. There are a lot of adjustments. the header itself is adjustable fore and aft. If it is that far off then the only thing you can try is to loosen the pin and move it as far forward as it will go. That is not much.
If you have any gap behind the rear window then you can try to move the frame forward by loosening the two bolts that mount it to the frame. This will result in adjusting the rear latch receiver forward. If this does not work then your only choice is to remove the staples on the top header and loosen the material. This may result in creases showing where it went over the header. You could try steaming to remove this. Otherwise the only choice is to install a new top.
To Soft top Frame Adjustment
