Distributor ?
Old Mar 16, 2010 | 06:29 PM
shemp's Avatar
shemp
Default Distributor ?
Why does my old dist. look different than the one I just got from Zip's
427/390 from a 68. Also I just got the correct rochester carb for this motor. The fuel filter has a vapor return line where does it connect on the lower end? Is there supposed to be another line going back to the sending unit on the tank. My car is a 67 but the motor a 68.
Shemp
Old Mar 16, 2010 | 06:38 PM
redvetracr's Avatar
redvetracr
PM sent
Old Mar 16, 2010 | 08:48 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Shemp Is all the above related to your engine issues last week? Dennis
Old Mar 16, 2010 | 09:16 PM
shemp's Avatar
shemp
Yes it is. I found the tach drive gears were gone. I believe the car jumped time somehow. I got the car running much better by advancing the timing way up. Then the tach stopped working and when I pulled the dist. I found out why. So I just bought a new one. I also new the carb was too big the plugs were black after just a few minutes. So I found a restored rochester 7028209 carb,it arrived today. I just realized 68 had a accelerator cable instead of mechanical linkage so I have to figure that one out. I hope to have it back together this weekend. Shemp
Old Mar 16, 2010 | 09:21 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
distributor on the left is a 65-66 BB only.
Old Mar 16, 2010 | 09:35 PM
Nowhere Man
why did you go with a 68 Rochester carb in place of a 67 Holle?. why would you create more problems?
Old Mar 16, 2010 | 09:39 PM
62Jeff's Avatar
62Jeff
Well, he does have a 68 motor in his car, so it's not unreasonable to think that a 1968 configuration might be the best way to go.
Old Mar 16, 2010 | 09:44 PM
Nowhere Man
not when its in a 67. I am not sure what intake he has on the car but a service replacement holly will bolt up and go with the correct fuel line. any 65-74 BB looks the same from the out side
Old Mar 16, 2010 | 09:48 PM
62Jeff's Avatar
62Jeff
I'm just suggesting that perhaps you should not be so quick to judge the actions of others.
Old Mar 16, 2010 | 09:53 PM
Nowhere Man
I am sorry. but I am just trying to figure out the reasoning behind this. I was always taught if there is a correct way or part to make your car better to use it then rather to "make" something else work. in the long run I find it easier to spend a couple more dollars and get the correct part. lets wait and see what the OP point of view. I am here to learn just like everyone else
Old Mar 16, 2010 | 10:24 PM
shemp's Avatar
shemp
I guess I just didn't do my homework on this one. I had a couple friends look at my problems and suggest a different carb, so I just figured the original would be the best for the setup I have. I hope it's not that big of a deal to get it to work properly. I am by no means an expert at this and learning more and more with each problem tha arises. I appreciate all the comments good or bad because that is how you learn. I still need an answer to the vent tube ?. Thanks to all Shemp
Old Mar 16, 2010 | 10:31 PM
Nowhere Man
if it was me I would sell the 68 carb and have your holley rebuilt. and use the 67 fuel line. to make a vapor fuel return line is not they way and your problem. that was for emissions.
Old Mar 16, 2010 | 10:40 PM
shemp's Avatar
shemp
Would it be ok to just block the vapor return line at the filter and use the carb and lines I just purchased? Shemp
Old Mar 16, 2010 | 11:12 PM
67L36Driver's Avatar
67L36Driver
Yes. That will work. Or get a filter same size/fittings as you have only without the vapor return.
Is your intake square bore (for Holly) or spread bore (for Rochester)?
I have an Edelbrock Qjet clone on a '68 #3883948 iron pass car intake on mine and it works great. Even the original air cleaner fits.
Old Mar 16, 2010 | 11:17 PM
shemp's Avatar
shemp
It's the original 68 intake (spread bore).Is that the Edelbrock #. I think the easiest route would be a new filter for about $8 rather than a new carb. Shemp
Old Mar 16, 2010 | 11:28 PM
67L36Driver
#3883948 is the casting number of the intake manifold.
Note: A #3883948 intake made for a '67 model will be a square bore for a Holly. The one I'm using is for a '68 full size car and is for a spread bore.
Casting Number is not the same as a part number.
Old Mar 16, 2010 | 11:29 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Those q-jets were always a hassel, Seemed like every one I came across had a big bog in it when you nailed it, you always had to screw around with changing metering rods to get them to run right. Spread bore Holley is the way to go.
To Distributor ?
Old Mar 16, 2010 | 11:41 PM
67L36Driver
I suffered with a couple Holly 6210's before changed to a Qjet. Too much hassel with the fuel leaks and wimpy power valves.
Havn't touched the Edelbrock since I bolted it on 10 years ago.
It is somewhat lean at WOT.
Old Mar 16, 2010 | 11:49 PM
Mike Ward's Avatar
Mike Ward
It's not a vapour return line and has nothing to do with emissions. Most C3s with a Qjet have a bypass line to return a small portion of the fuel flow back the tank. This recirculation reduces the temperature of the fuel in the pump inlet and in turn reduces or eliminates the possibility of fuel vapour lock. The act of bypassing the fuel also reduces excess inlet pressure to the carb slightly.
Nothing wrong with a qjet if it's set up properly and not fooled around with.
Old Mar 17, 2010 | 12:14 PM
JohnZ's Avatar
JohnZ
427/390 from a 68.
Which one is your old one and which one is the new one from Zip?
