Rear gear question
Old Mar 17, 2010 | 01:22 PM
TWINRAY's Avatar
TWINRAY
Default Rear gear question
Is a 3.36 gear to high to get my '67 with a 327/350 off the line with a 2.20 1st gear? I'm not talking drag racing it (as it has a 4.11 in it now) but just for general driving. Thanks.
Old Mar 17, 2010 | 01:35 PM
Plasticman's Avatar
Plasticman
The rule of thumb is multiply the rear end times the 1st gear ratio.
For you it is 3.36 X 2.20 = 7.392.
Generally a 10 or a tad higher is desired. Especially with a higher cam'd engine, like the L79 you have. My 66 327/350 had a 3.70 rear gear, which worked very nicely.
With the 3.36 with the 2.20 first gear, expect to be slipping the clutch (to get off from a stop).
Note that a 3.36 rear with the 2.56 wide ratio Muncie would = 8.60 total. Still not ideal, but far better than with the 2.20 close ratio Muncie.
Also note that my existing MY6 OD trans has a 3.09 first gear coupled with a 3.55 rear gear. That = 10.9695 and is a dream to launch smoothly (but 2nd gear does come up quickly).
Plasticman
Old Mar 17, 2010 | 02:12 PM
Allcoupedup's Avatar
Allcoupedup
I used to have a l76 with a 3.36 gear with a close ratio Muncie with a 2.20 first gear and it sucked. I swapped transmissions to a close ratio with a 2.56:1 first gear and it was a huge improvement.
Recently I changed from 3.36:1 to 3.70:1 rear end and it was another huge improvement.
To answer your question, yes I think the 3.36:1 is too tall for a l79. THe wide ratio is a great compromise because you will get a shorter total first gear ratio to the rear wheels but you will still get a 1:1 ratio out of the transmission in 4th gear for cruising.
Brian
Old Mar 17, 2010 | 02:15 PM
TWINRAY's Avatar
TWINRAY
That's what I thought. I had a '68 GTO (360HP 400") with a 2.20 1st gear and switched to a 3.36 from a 3.90 after the latter went south. It was fine when you were rolling but it bogged like krap from a start. Oh well, it was just an idea .
Old Mar 17, 2010 | 05:21 PM
mhanley's Avatar
mhanley
I have 3.55 in my 67 L79 and I just love the way it comes off the line, I think its the ideal gear for any type of driving. I also had it in a 67 L71 car it was great.
Mike
Old Mar 17, 2010 | 05:39 PM
w1ctc's Avatar
w1ctc
I have a 3.5 rear and 2.20 first. It's always been kind of lazy off the line but it pulls great with a street start ( 20 mph punch). I would gladly give up 10 or 15 mph peak in first for a better off the line feel.
Old Mar 17, 2010 | 05:50 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Gearing
I have a L79 in my 68 with a 3:70 and an M21. It is a great compromise for street and highway. The 3300 rpm on the highway at 70 MPH can be noisey on a long trip. I did put aTremec in my 66 L79 with a 4:11. Love that overdrive. Jerry
Old Mar 18, 2010 | 10:13 AM
Kensmith's Avatar
Kensmith
Go hear and play with the different gears for tranny, rear end, and tires:
http://www.5speedtransmissions.com/gear_calculator.html
Old Mar 23, 2010 | 09:51 AM
TWINRAY's Avatar
TWINRAY
Hey Jerry,
What's the 1st gear ratio in that Tremec?
Fred
To Rear gear question
