1965 vent window adjustment?
Cruise-In III Veteran
Hi All,
I've done a search and found quite a bit of info on adjusting doors, windows and vent windows.
I hate tackling this but I've got to remove the driver's door to do 2 out of 3 things:
1. Fix 3 loose rivets on the front outer jam of the driver's door (ordered the McMaster-Carr #93865A230...Projection Weld Studs [THANK YOU JOHNZ!]). (See 2nd pic below)
2. Replace the lower hinge pin and bushings.
Doing this should cure the door's tendency to "climb" onto the striker.
3. Adjust the driver's vent window so that I can bring the top part in by a 1/8".
Here's a pic of my driver's vent window currently installed. I believe the bolt I need to turn for this adjustment is the lower front window channel nut, right? I need to loosen the 2 above near the sill when I do this, right? I just want to make sure I do this right the first time. Just curious to know what that threaded stud with a slot in it is for?
Sure enough, I now can see why the door sounded like loose change. Looks like I'll be ordering the mechanism that the ball is attached to which allows the door to open from the inside. All kinds of play there. As well as replace the window channel sash.
I'm hoping I can avoid having to repaint the car 'cause of this project
I looked at the innards of the door after removing the door panel and I think I need to remove the side glass to get at installing those studs when I remove those rivets. Anybody offer any tricks to installing these?
Realize I'm throwing a lot out here but man I'm intimidated a little by this project...can just see me scratching/chipping the paint...UGH!
Thanks in advance!
Jim
In God We Trust!
Thanks in advance!
Jim
In God We Trust!
I'm a C1 guy but I can tell you that I keep several rolls of the blue 'quick release' painter's tape around. If you even think there is a shadow of a chance of a paint chip anywhere...put a double layer of this product over the potential 'hit' spot and many, many times it will save your backside...
Frankie the Fink,
Thanks for the cautionary with the painter's tape. I DO plan on covering the leading edge of both the fender and both ends of the door as well as the quarter edge.
So, am I correct that I need to loosen the 2 top big bolts holding the vent window as well as the nut at near the bottom which holds the front window channel in order to make the top part of the vent window lean in more???
The glass has to come out right? in order for me to replace those 3 rivets on the leading door jamb in the pic above? I apologize if I'm sounding like a clutz here but I DO need some reassurance on approaching this task.
THANKS!
Jim
In God We Trust!
THANKS!
Jim
In God We Trust!
Adjustment
Jim:
The tilt is adjusted by the threaded stud which moves the frame inboard/outboard. The top 2 bolts need to be loose to allow the frame assy to pivot.
Also, don't forget the adjuster at the bottom of the vertical channel. I loosen this up first, and then adjust the frame tilt per above. Last, I snug up that lower track adjustment so there's no strain on the channel.
Mike
Mike
Jim:
Mike
Mike
As mentioned, be sure the bottom track bolt is loose to allow free movement of the vent window frame when adjusting.
You may be able to get to the rivets for replacement without removing the side window glass, I don't remember for sure. I'd check by rolling the window up/down before I went to the trouble of removing the glass just to be sure.
2 large top bolts
Jim:
Mike
Mike
2019 Corvette of the Year Winner
St. Jude Donor '15
