64' 327 idle issues
Old Mar 26, 2010 | 04:16 AM
  #41
TonySan99's Avatar
TonySan99
Originally Posted by Frankie the Fink
I'm going with the low (or stuck) float setting (which MikeM mentions above)...
An old mechanic's trick is to rap sharply on the side of the carb with the plastic handle of a screwdriver to knock a stuck float loose (if in fact that's the issue)..
After talking to a buddy of mine who knows sbc real well, he thinks its a float issue, hes comin to check it out later today.
Old Mar 26, 2010 | 04:18 AM
  #42
TonySan99's Avatar
TonySan99
Originally Posted by 64_365
There is only one idle speed screw, and it's on the throttle linkage. It's been mentioned once before in this thread.
Have..... you..... tried....... adjusting it?
Yes, ive adjusted the idle / fast idle screw to the point of exhaustion, i wish that was the problem.
Old Mar 26, 2010 | 08:21 PM
  #43
64_365's Avatar
64_365
Idle screw is on the driver's side, fast idle is on the passenger side, they're not the same.
If you can keep it running by holding the throttle open, then you should be able to screw the idle screw in enough to keep it running.
Old Mar 26, 2010 | 10:37 PM
  #44
TonySan99's Avatar
TonySan99
Well i had a buddy come over and help me out, he got it running and set everything up nicely. I was close but couldnt get it on my own. Thanks for all your help, it was a good learning experience.
Old Mar 26, 2010 | 10:41 PM
  #45
5thvet's Avatar
5thvet
glad it worked out!
Old Mar 27, 2010 | 06:48 AM
  #46
MikeM's Avatar
MikeM
The rest of us would like to learn too. What was wrong with it?
