Help!! Rim offset question
Old Mar 20, 2010 | 08:30 PM
Voice123's Avatar
Voice123
Default Help!! Rim offset question
I just purchased new American Racing Torque IIs. These were 17 x 7 with 4 inch backspace. However the offset they sent me is 1 mm on these rims. Should I be concerned?
Old Mar 20, 2010 | 08:57 PM
Voice123's Avatar
Voice123
I think offset is different from backspace.....
Old Mar 20, 2010 | 09:37 PM
Voice123's Avatar
Voice123
Anyone??? I need to know if I need to return these back so your expertise would be appreciated.
Old Mar 20, 2010 | 09:56 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Your correct. I was watching the mecum auction and just skimmed over it. I should have paid more attention.
Being Saturday evening, I am sure you will get many responses by tomorrow.
Old Mar 20, 2010 | 09:58 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
If the offset is truly 1mm I wouldn't worry about it, but are you sure about this measurement?
Try this linky for more info; https://www.rsracing.com/tech-wheel.html#backspace
Old Mar 21, 2010 | 12:09 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I think the 17x7 is a 4" backspace standard wheel. Which would be about zero offset, a 7" rim is about 8" flange to flange. That rim will work but depending on tire size will need the fender lip clearanced. A 225/50/17 will probably rub with stock fenders. This size rim is a better option, http://forums.corvetteforum.com/c1-a...17-wheels.html. Ron B.
Old Mar 21, 2010 | 11:19 AM
Kensmith's Avatar
Kensmith
I have 17X8 with 4 1/2" backspace and 225/50 tires. No problems with front or rear clearances. Very close at rear though. 17X7 with 4" backspacing will be fine. I'd be more concerned about the tire width but the 4" backspacing on a 7" wheel will give equal clearance at both rear wheel opening and trailing arm. I would not go any wider than a 9" wide tire. 225/50 is 9.1 to 9.2 inches wide and will be very close.
Old Mar 21, 2010 | 05:19 PM
Voice123's Avatar
Voice123
Thank you all for your help......it seems that I will be okay with my offset and your suggestions on tire size is really helpful.
To Help!! Rim offset question
