Balancing tire/wheels
Old Mar 22, 2010 | 06:58 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Default Balancing tire/wheels
Have any of you had any tire balance issues with any aftermarket wheels...NOT steel wheels? I have been doing some reading on the Garage Journal about this. Some guys have had success with vintage bubble balancers and dynamic balancers. Some balance the wheel by it's self, then with the tire on and have cured some issues. Some actually balance them on the car. This of course is done with some real vintage balancer. I'm having an issue with my left front, it seems to vibrate, but not at the same speed all the time. The tires shop is working with me on this, but I want to know more. Dennis
Old Mar 22, 2010 | 07:03 PM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
Sometimes a broken shock will give the same symptoms. I saw a small pickup the other day who's right wheel was bouncing up and down off the pavement @ 30mph due to a dead shock absorber.
Old Mar 22, 2010 | 07:31 PM
JohnZ's Avatar
JohnZ
Do they have a Hunter GSP-9700 balancer?
Old Mar 22, 2010 | 07:45 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Check for out of round tire. Even new ones. I will never by Pirelli again because of the number of out of round tires.
John
Old Mar 22, 2010 | 07:58 PM
woodsdesign's Avatar
woodsdesign
I had an issue with aftermarket wheels and new tires on a C-5. the technician had to do a "hi tech" balance. Meaning that he would rotate the tire on the rim to get the weight equally distributed. It took a long time and it wasn't perfect. I agree with John Z that Hunter makes the best equipment so I would check that out.
I also found the Cokler radial tires are terriably out of balance and need a lot of weight.
Old Mar 22, 2010 | 08:03 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
:agree:
Roadforce balance is the hot ticket.
Old Mar 22, 2010 | 08:40 PM
Kensmith's Avatar
Kensmith
Originally Posted by Sky65
:agree:
My son works at a custom wheel and performance shop. They only use the Road Force balancers. It will tell you everything about the wheel and tire.
Old Mar 23, 2010 | 09:16 AM
Bluestripe67
My shocks are gas and the rebound/jounce is equal on both sides of the front. The tire shop owner cut his teeth on balancing etc. We are going to separate the tire and wheel, balance the wheel and then remount the tire, balance both and then check the balance on the car with an old school spinner motor. Dennis
Old Mar 23, 2010 | 10:52 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
A steel belted radial? Perhaps a broken belt. Many years ago I had a balance problem with a Michelin steel belted radial and that was the problem, balanced OK but had a vibration at speed.
Charles
To Balancing tire/wheels
