63 Hard Cold Start
A couple pumps of the gas and then crank it over, it should fire instantly. Even if the choke is not working.
Take the air cleaner off and look down in the carb. You should see two good streams of gas shooting into the center of the carb when you do this.
Do it with the engine off, please.
Check the point dwell if the above is okay and/or provide a little more detail.
Scot
Don
Your car should start following the instructions in the owner's manual. For a cold start, it says something like "push the gas pedal to the floor and let off". "Then crank the engine to start". If your engine has been run in the last couple days, it should start right up using that method.
If your engine hasn't been started for a week or two, you probably don't have any gas in the carb bowl. Pumping the gas at this point won't do any good. You'll have to get gasoline in the bowl (so the pump will work) one way or another.
There's at least three ways to do it. One is to crank the engine for 20-30 seconds and the pump will push the gas into the bowl. Then, you can pump the gas a couple times and it should fire right off.
Use a basting bulb to fill the float bowl with gas. You have to remove the air cleaner lid to do this. This would allow you a normal cold start.
Or, you can use a squirt oil can with gas in it to squirt a little gas in the carb opening. Remove the air cleaner lid for this also. The engine will fire and then probably die but should start right back up and run.
I don't like cranking on the starter but I like yanking on the hood release even less. Sooner or later that will lead to a broken hood cable.
I don't think anything about using these methods but if you're a stranger to handling gasoline, proceed with caution and don't put too much gasoline in the carb. If you do it a few times, you'll get the hang of it.
If you don't get the hang of it or don't feel comfortable doing these things, you can install an electric fuel pump in your fuel system. That will give you almost instant starting even if the car hasn't ran in six months.
cranked it for a while. The bowls have to refill, then the accelerator pump can pick up fuel and it starts. Probably needs a good overhaul. There is a good article in this months Corvette Fever magazine. It shows step by step how to overhaul and afb carb. The kit is about $45.00.
Could also be a bad power valve.
