Lubing a 1961
Lubing a 1961
I'm driving my '61 more and more now and there are a few folks on the forum whose advice I take pretty much as gospel. Tom Parson's says lubing the chassis at 1,000 mile intervals is mandatory. Seems excessive but I'll go with it based on his experience. Last lube job I played detective trying to find all the places to lubricate the car.
Where is the best depiction of the lube points and are there any zerk fittings that should be added anywhere ? I believe some folks have added one on the clutch Z-bar....
Best to add the Zerk to the Z-bar when you have the bar out. I know people use the "grease the drill bit" method to contain the amount of cuttings from getting into the shaft, but it only takes one small piece of errant steel cutting to screw up the whole purpose of installing the Zerk.
A good time to have done it, was when you had the 5 speed installed............
John
1000 miles for sure in the service manual for 53/62 it shows all lubrication points! I know the seller of my c1 cleaned the underside so good that there could not have been grease found out real fast !!! gone now after full grease job, and as far as learning about a c1 it never seems to end , know a wrench well is the rule i guess
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
On 53-62 Vette frontends, if it is a joint, it has a grease fitting------------some where!
Upper-lower A-frame inner shafts-1 fitting on each end (8).
Upper-lower A-frame outer shafts-1 fitting per shaft (4).
Kingpin/bushings-2 fittings per spindle (4).
Tierod ends-1 fitting on each end (4).
Drag link-2 fittings (2).
MOST U-joints-1 fitting each joint (2).
Total-24 grease fittings.
YES!!! It is important to grease these frontends frequently, because ALLLLLLLLLLLLLLL joints are metal-to-metal! There are NO rubber bushings or ball joints.
If you keep them greased, they will probably outlast all of us.
And here are a couple of examples of what can happen when not regularly greased.
This is a kingpin which was seized in the bushing, and the bushing had seized in the spindle bore.
BADLY worn upper-inner shaft end.
Badly worn lower-outer shaft and bushing.
With this kind of wear, especially if several joints have significant wear, the frontend alignment/geometry is constantly changing.
Tom Parsons
Tom Parsons
Nope, the third arm bearing is just packed in grease. I always just use a sealed bearing when I replace one. The bushings will last almost forever if they are kept lubed, but once they go dry, they will be toast in short order. It is not that uncommon to find original 50 year old bushings that are still like new when a car has been kept greased!
Regards, John McGraw
Thanks DZAuto and others....now that I'm putting miles on the car maintenance on the original components is nearly a part time job...
I have 3 spares on the shelf-------------no, none of them are for sale. But if anyone who owns, AND DRIVES, their 53-62 Vette frequently, this would be a part to acquire and store for the future.
Tom Parsons
Wow 24 fittings! I knew their were a lot and always greased them once a year when I changed the oil and adjusted the brakes.I had the king pins replaced about six years ago.Two years ago I went with JMR IFS,now i only have four fittings to grease.
Picture of old IFS with JMR IFS on the floor:
http://forums.corvetteforum.com/phot.../ppuser/347394
I don't have a lift at home so I wind up walking around with the service tech under the car at my favorite garage with the ST-12 in hand showing him what to hit with the lube gun...
Tedious but then I know everything gets greased...so far, judging by this thread, I'm not forgetting anything.
Tom Parsons
I also stumbled across a maintenance manual for the TriCo windshield washer and wiper system I picked up on eBay that has some info I've never found anywhere else..
Frank
There is a picture of it Tim (middle of the top row); I have found the manuals in the picture will let an amateur do just about any job that he has the tools and nerve to tackle. A nice addition are the Dr. Rebuild laminated wiring diagrams - lifesavers! The AIM (assembly manual) is now available on CD-ROM from Wilcox and also VERY useful
Frank
Frank
Tim
I don't have a lift (whimper whimper) and the last few years I have been averaging about 5,000 miles per year on my 60. Thats 5 lube jobs per season. I know you have the ramps, stands, technical know how, weeell at least enough to be able to push the button on the grease gun!
The toughest fitting to find and service is the front driveshaft grease fitting.
Frank you should invest in a battery powered grease gun and do it your self. Do it on your time, and no more trips to the garage.
Tom Parsons
