C2 side mirror.
Old Mar 29, 2010 | 06:53 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Default C2 side mirror.
Can anyone vouch for one of the vendors on the best C2 side mirror? I bought one from LIC and it did not last one year. It is cheap. I have pulled the mirror portion out and tried to rivet/peen it as JohnZ suggested but it did not last. My original one is not good either. Chrome is back and it falls also. Tried to peen that one too but it didn't work. I am just looking for a serviceable one that will go on my car as a driver. It doesn't have to be show chrome quality, just quality construction. Any thoughts???
Steve
Old Mar 29, 2010 | 07:33 PM
RMBLROAR's Avatar
RMBLROAR
I replaced my '66's mirror years ago and got it from Paragon. They're probably all made by the same source but mine's lasted so far....
Good luck
Old Mar 29, 2010 | 07:42 PM
62Jeff's Avatar
62Jeff
I bought one from Corvette Central, but after a year or two the mirror head began flopping around.
Then I bought one used that was said to come from a different vendor, and it is too wide at the base and flops around on the same door mount on which that the Corvette Central unit fits properly.
Ultimately I took my Corvette Central mirror apart and whacked the pins a few times to tighten up the floppy head. Don't know how long that will last, though, and based on your comment I suspect not long.
My main point, is I have 2 mirrors that appear to have come from 2 different vendors, and fit differently.
Old Mar 29, 2010 | 08:16 PM
magicv8's Avatar
magicv8
I cut a small piece of aluminum flashing about an inch and a half long and narrow enough to fit between the peened posts, then cut a V notch about .75inch deep into one long end. I slipped the V notched end of the aluminum between the posts, then pulled (with pliers on the V notch ends) it until the swivel got past the point of the V notch - so there is a (higher coefficient of friction) piece of aluminum between the ball and the plate peened to the mirror.
That was 7-8 years ago and still no problems.
Old Mar 29, 2010 | 09:20 PM
Dennis Beck's Avatar
Dennis Beck
Good luck
My new one is also from Paragon. Beautiful chrome and it has performed well.
Old Mar 30, 2010 | 05:33 AM
66BlkBB's Avatar
66BlkBB
Magic,
My problem is that the posts are already bad. I can't slip anything under as the tops of the posts will pull through the metal strip that is already there. I tried peening the posts but there wasn't enough material left to get a good solid rivet type head on them. I have to go to a new mirror again.
Steve
Old Mar 30, 2010 | 09:50 AM
Mike Geary's Avatar
Mike Geary
Default Bubba fix
Position the mirror just where you want it and then wick some Super Glue into the ball/socket joint.
It's invisible, the bond can be broken loose if necessary, and you get a gritty build-up between the surfaces that increases friction.
Old Mar 30, 2010 | 10:02 AM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
I'll 2nd what Mike suggested. I used thread locker and achieved the same "bubba fix." It works, stiffening up the mirror head movement.
Jim
In God We Trust!
Old Mar 30, 2010 | 10:24 AM
magicv8's Avatar
magicv8
Originally Posted by 66BlkBB
Magic,
Steve
one of my posts was loose too. I drilled a small hole in it, ground off the peened surface and inserted a small pan head sheet metal screw. It's still there.
Old Mar 30, 2010 | 10:37 AM
66BlkBB's Avatar
66BlkBB
This sounds like a better idea. I will try that. I can't lose anything. The damn thing is no good the way it is. Thanks for the tip.
Old Mar 30, 2010 | 06:51 PM
66BlkBB's Avatar
66BlkBB
It worked!!!!!
To C2 side mirror.
By Michael S. Palmer | 2026-06-03 11:00:24
