hood adjustment
Old Apr 3, 2010 | 12:04 PM
vt65's Avatar
vt65
Default hood adjustment
installed a bb hood on my '65 looking for a way to get it down on the passenger side nose, besides cutting the hinge is there any other way to drop the corner, my stock small block hood fits perfectly so i don't think it's the body that has the problem...
Old Apr 3, 2010 | 12:08 PM
JohnZ's Avatar
JohnZ
Where the body side of the hood hinge attaches to the inner fender, install shims at the rearmost attachment, between the hinge and the inner fender; that will tip the pivot point of the hinge downward, lowering the front edge of the hood.
Old Apr 3, 2010 | 12:12 PM
vt65's Avatar
vt65
thanks...going to try that now
Old Apr 4, 2010 | 02:51 PM
64con's Avatar
64con
Default Hood Alignment
did this work for you. I'm having some issues with the front of my hood not fitting.
Old Apr 4, 2010 | 02:58 PM
vt65's Avatar
vt65
it did drop it about 1/8 th inch with 3 shims which i cut in half , need another 1/8th so i'll cut and weld the hinges, don't know if i should add more shims than that
Old Apr 4, 2010 | 03:52 PM
64con's Avatar
64con
thanks for the reply, Do you think that you have approx. 1/8th in shims to get the result that you have I'll try the same. thanks john z for your original reply , John I hope you didn't read anything into me asking if suggestion worked or not your wisdom is legendary
Warren
Old Apr 4, 2010 | 06:02 PM
vt65's Avatar
vt65
Warren
yes 3 shims would be about 3/16th thick....and yes John Z, that was a good suggestion...
To hood adjustment
