Please help clarify Holley's 2818 & 2818-1
Just would like an explanation on these Holley numbers. I know that stock carbs for say a 64 was a 2818, dated like 302, model 4150. Now, when were these 2818-1 carbs made, dates are like 2828, why four numbers, are they still a 4150. Are these carbs the same and are the -1 carbs correct. I would like to know more about the 2818-1 carbs, please.
Both the 2818 and 2818-1 are 4150s part number 3849804 and correct for 64 365s and 65 365s and 350s. The list number changed to the -1 during the summer of 64. Most 64's should be 2818 and most 65s 2818-1. The different date codes are a factory carb, 3 digit, or replacement, 4 digit. The 3 digit is year, month, week: 302= 63 Oct second week. The four digit is julian date, year. 2828= 282d day of a year that ends in 8.
Example : L76 3rd week of November 1963.
Will a 2818-1 on a '64 L76 result in a point deduction at an NCRS meet? Yes
A '64 2818 carb will only have four digits stamped into the metering block, no -(list) numbers. I have a '64 with a date code of 451, 1st week of May '64.
Cruise-In III Veteran
Curious about the 2818 I'm running. The 3 #s are 431. So, year, month, week, right? Thought the 2nd digit in your example would have been a letter. Do I read mine to be year: '64, month: March?, then week: 1st?
Thanks!
Jim
In God We Trust!
Thanks!
Jim
In God We Trust!
Received 1,857 Likes
POSSE ZR-1 Driver
The way I read it, both.
3 digit dates in the early 60's (63-65)
4 digit dates in the 70's
I understand that the 2818, 3 digit date carbs, are from the sixties. But were the 2818-1 carbs also from the sixties, saying that there are some 2818-1, 3 digit dates, or are the 2818-1 all with 4 digit dates?
POSSE ZR-1 Driver
All 2818 should be 3 digit dates (produced between late 63 and late 64). 2818-1 could be either 3 or 4 digit dates. I have a 2818-1 on my car with a date of 482 (1964, Aug, second week). The Carb is not original to my 64. I'm thinking it was originally on a very early 65.
2818-1 dates
My 65 carb is dated 533. I have seen replacements, with 3 and four digit dates.
I have an early 2818 dated on the opposite side of the air horn that is fully restored , will trade for feb or march early april 65 2818.
Lots of small differences in the various castings (originals and later versions) that comprise the 2818.
2818's and 2818-1's used in production in '64-'65 all had 3-digit date codes. Service replacements made through 1972 also had 3-digit date codes. Service replacements made after 1972 had 4-digit date codes.
Guys,
Have a Holley R2818-1 with 3 digit date code 135. Makes no sense, right? The 2818-1 should be for a '64 or '65, yet this 135 code would indicate 1961 or 1971, when the 2818-1 wasn't used. Thoughts?
Thanks,
Jim
Thanks,
Jim
A "135" date code on a 2818-1 simply indicates a Service Replacement manufactured the third week of March, 1971. The 4-digit date coding didn't go into effect until 1972.
I don't follow pricing like that, but whomever buys it will take a 20% (8-point) originality hit in judging for "date". Value will depend on whether it works, whether it needs a rebuild, cosmetic condition, etc.
1850, 2818, 28181, 431, blocks, carb, carburetor, date, difference, holley, list, metering, production, r2818a, replacement, years
