Composite Spring Ride Height
Old Apr 7, 2010 | 11:11 PM
WrightOn64's Avatar
WrightOn64
Cruising
Default Composite Spring Ride Height
If I upgrade to a composite rear spring, will I be able to adjust ride height?
64 Coupe...thanks!
Old Apr 8, 2010 | 12:00 AM
62Jeff's Avatar
62Jeff
Yep, same as with the original leaf spring, by adjusting the long bolts on the ends of the spring.
Old Apr 8, 2010 | 09:08 AM
WrightOn64's Avatar
WrightOn64
Cruising
Cool...and thanks.
My current one is flat...may even be starting to bow down! I haven't played with the bolts to see if it just needs adjusting but heck it's 46 years old and was a road racer...probably can't hurt to redo the whole rear end with new stuff while I have it apart.
Old Apr 8, 2010 | 09:35 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
This could turn out to be, "while I'm at it" type of project. Let me fan the flames. What is the condition of your front suspension, in particular the springs. It's possible with the new rear spring, and any other parts upgrads, you will get a very different handling car. May even be a little unruly. Balancing the suspension is something to consider. Dennis
To Composite Spring Ride Height
