Readiator cap question
Old Apr 10, 2010 | 02:13 PM
ren's Avatar
ren
Default Readiator cap question
This may be a stupid question, but what difference does the pressure of the radiator cap make? When I bought my car it had a 3 lb. cap. Somehow I ended up with a 13lb cap. I now have a 7 lb. cap
Old Apr 10, 2010 | 02:19 PM
62Jeff's Avatar
62Jeff
The boiling point of your water/coolanat mix raises a few degrees for every pound of pressure you add.
However, since the system was designed for a certain PSI, I would stick with a radiator cap rated at whatever PSI your car originally used.
