power steering
Old Apr 10, 2010 | 08:32 PM
robburr's Avatar
robburr
Default power steering
is there a power steering gear box of any other gm that will fit 66
Old Apr 10, 2010 | 08:49 PM
vt65's Avatar
vt65
yes, do a search on Bourgeson steering boxes robbur, there's lots of good info, your steering box is the same one that is used for manual or power steering only difference is that power assist comes from a slave cylinder attached to a power steering pump.
Old Apr 11, 2010 | 10:34 PM
JohnZ's Avatar
JohnZ
Nope. Corvette power steering had nothing to do with the steering gear - the gear was the same with either power or manual. If you want to remove the linkage-boosted Corvette power steering system and replace it with an integral power steering gear like the full-size cars used, you'll have to go aftermarket.
Old Apr 12, 2010 | 08:30 AM
vt65's Avatar
vt65
pm sent to you JohnZ
To power steering
