C1 Antenna Cable
Old Apr 12, 2010 | 03:23 PM
Pierre's Avatar
Pierre
Default C1 Antenna Cable
I will be attempting to install an antenna cable in the original location in my ’57. I have installed some of these before but always when the fuel tank was out. Being basically lazy, I don’t feel like taking the tank out if I don’t have to. Has anybody installed one of these cables with the fuel tank in in a C1?
Thanks.. Pierre
Old Apr 12, 2010 | 05:43 PM
mike coletta's Avatar
mike coletta
Pierre,
The tank doesn"t effect the location of the cable. It runs in the chase along side the sill plate, behind the convertible top brackets, and then is clamped along the topside of the convertible top well. I then goes through a hole, into the trunk, and and is held in place along the top edge of the trunk rail with "glued in place" clips, until it gets to the mast. Hope this helps.
Mike Coletta
Old Apr 12, 2010 | 06:34 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Something like...on my '61...
But my Noland Adams C1 Tech Ref & Guide show the earlier cars ('57) runs, apparently, almost on top of the left side rear wheel well .. I can't tell if that is in the gas tank cavity or not by the picture...but I'd go with Mike's guidance.
Frank
Old Apr 12, 2010 | 07:09 PM
Pierre's Avatar
Pierre
Frank
I don't think '56 and '57 are the same as '61 and '62. I can get the cable from the trunk to the soft top area. From there I can see a small part of the rear harness but can't tell where it goes down to the sill area, this is where the antenna cable should also go. If I remember right, it is quite obvious with the tank out but with the tank in, I just can't see where the antenna cable and rear harness go in and down to the sill area.
Old Apr 12, 2010 | 11:09 PM
TroyPyles's Avatar
TroyPyles
I'm pretty sure there is room with the tank in. But not much. You will of course need to remove the tank cover, and the fill pipe so you can get your arm in there to pull. Once that is done the tank is easy to get out...unless it's full!
Old Apr 13, 2010 | 01:23 AM
Vette Daddy's Avatar
Vette Daddy
Ther will be grommets in the small holes that enter and exit the rocker channel. Access with the tank in the car may prove difficult. The area between the trunk and gas tank area will have caulk between the rear upper surround and the floor pan. You can dig it out with a screwdriver until you can make room to pull the new cable through.
Attach the new cable to the old cable and pull it through. TIP - spray the cavity with WD40 so it pulls through the caulk easier.
Good luck, it can be done.
Worse case, grind a small channel on the underside of the inner fender well where the cable is sandwiched between the upper surround and floor pan. After the new cable is installed, just resin/mat over it and undercoat.
Old Apr 13, 2010 | 08:07 AM
mike coletta
Sorry Pierre,
I was wrong on my quote. I forgot that the 56/7 cars run the cable through the tank well. The last one that I did (several years ago), I installed the cable with the tank out. My guess is that you could still do it, but I would remove the grommets so that you have some extra room. Sorry about the misinformation. Good luck.
Mike Coletta
To C1 Antenna Cable
