Distributor Spring Question
Old Apr 17, 2010 | 09:23 PM
62RDSTR's Avatar
62RDSTR
Originally Posted by Donald #31176
Which VAC are you using? With 20-21 inches engine vacuum a B-1 or B22 VAC will work well. Your idle timing should read about 26* w. the VAC connected to a full time source and initial timing @ 10*.
Thats a good question. The one I pulled off was a B1. I didn't realize there is a difference on them but the one I put on, going by memory, is a B33? It is an Accel 31034. Seemed pretty generic but I'm guessing that it is bringing on much more advance than the B1.
The
Old Apr 17, 2010 | 09:25 PM
SupremeDeluxe's Avatar
SupremeDeluxe
Originally Posted by 62RDSTR
Great! The two gold springs has made the engine run great at idle and at all RPMs without any Vacuum Advance.
Jim,
You'll have to experiment to see if it will run OK with the vacuum now. Even if the bucking/surging goes away, you still may have some part throttle spark knock under conditions where the mechanical advance is coming in and manifold vacuum is still high enough to be adding vacuum advance (i.e., between about 2200-3000R).
Nick
62RDSTR's Avatar
62RDSTR
Originally Posted by SupremeDeluxe
26* is about right on with the initial set at 10*. I don't know which can is most correct for your application. However, if you have 40* idle, something is amiss with the mechanical advance mechanism. You will need to start with the gold springs, as I am absolutely sure that will prevent any mechanical advance below 1200R. Then you can ascertain how much base timing you have and how much advance the vacuum canister is adding.
If all seems normal after doing the above, then disconnect and plug the line to the vac and use a dialback light to see how much mechanical advance you're getting and how fast it comes in. I know others will disagree here, but in my opinion even the stiff springs will allow the vacuum advance to come in too soon for use with pump gas. You can experiment with cutting coils out of the gold Accel/ Mr Gasket springs to elevate the curve in the RPM range, or better yet find some OE springs from an old distributor that are made from larger wire diameter and therefore have a higher spring rate.
Thanks,
With the gold springs, my initial timing is 10* at 800 RPM. Without any VA, at 2400 RPM the advancement is approximately 26-28* using a dialback. So total 36-38 without vacuum at 2400RPM.
Old Apr 17, 2010 | 09:40 PM
62RDSTR's Avatar
62RDSTR
Jim,
Nick
The bucking/surging has completely gone away using just initial & mechanical with approximately 36-38* total advance at 2400RPM. Currently, the VA can is not in use while I take a step back and regroup with the changes that I've done today.
jim
Old Apr 17, 2010 | 10:52 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
That sounds pretty good...with the vacuum advance and the timing 'all in' at speed you don't want over 50* ... prob 48* would be best.... Looks like you've zeroed in on the problem...
My little 283 is 'all in' at about 2900 RPM and that has given me good response throughout my typical driving range...
Old Apr 18, 2010 | 11:48 AM
Donald #31176's Avatar
Donald #31176
I still think you'll have to recurve the distributor to a less aggressive map.
My 300 hp distributor mech advance map
Start @ 800 rpm
14* @ 1600
26* @ 3100 rpm
Using 10* initial timing yields 36* total timing @3100 rpm. Im using HD Borg Warner 112 Hp points, Accel rotor & cap that are USA made and a B22 VAC . I can idle smoothly @ 600 rpm and my cruise timing (part throttle) is 51*.
Old Apr 18, 2010 | 08:46 PM
62RDSTR's Avatar
62RDSTR
Start @ 800 rpm
14* @ 1600
26* @ 3100 rpm
Thanks Donald,
I'm so happy to get her running good again but will re evaluate. I had an Accel universal VAC that is throwing 30* advance at idle. I have it plugged right now but will replace with either a B22 or a B1 VAC.
I have the top end and the bottom end of the curve mapped but I didn't take any measurements in the middle. In addition, I may experiment with a couple different spring combos. This was a first for me (points, gaps, dwell, springs, etc...) so know that I have a better feeling on how all of these interact with each other I can regroup and get a good setup.
Good news is though she runs better than she has ever!
I appreciate your feedback.
Jim
