Capacitor - what does it do?
Old Apr 20, 2010 | 09:21 AM
DanTanna's Avatar
DanTanna
Default Capacitor - what does it do?
I have a '63 vert and I was re-installing my guage cluster and the wire leading to the capacitor (low on the ignition side of the cluster) popped out of the capacitor. What does this particular capacitor do? It is not hooked to the ignition, so I assume my car will still start, but it is wired to the harness. From the various catalogs and diagrams I see, my 63 has two, one on each side and the 64-67s have three behind the cluster. I ordered a new one (expensive little bugger), but was curious as to what it does. Thanks.
Old Apr 20, 2010 | 09:23 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I'm betting its for radio noise suppression...the ones behind the dash usually are...
Your car should start fine and there are so many C1s/C2s running around with blown capacitors right now that aren't even noticed its probably amazing. (My car may be one of them!)
Old Apr 20, 2010 | 10:48 AM
5thvet's Avatar
5thvet
For radio interference.
Old Apr 20, 2010 | 11:19 AM
BLee's Avatar
BLee
From my ex-Marine instructor in fundamental electronics class during avionics training...."capacitors are like a rubber, they hold the charge and pass the effect".
BL
Old Apr 20, 2010 | 11:25 AM
DanTanna's Avatar
DanTanna
Old Apr 20, 2010 | 12:05 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
They're all for radio suppression. You could forgo the capacitors and use an RF filter from Radio shack.
Old Apr 20, 2010 | 09:44 PM
claf's Avatar
claf
Default Capacitorless
My 62 has zero capacitors ! How and where would you wire a RF filter into the electrical system ? Thanks, Bob
To Capacitor - what does it do?
