Drum adjustment
Old Apr 23, 2010 | 11:47 AM
bmcnitt's Avatar
bmcnitt
Default Drum adjustment
My friend from work always says that his uncle "adjusts" his drum brakes by going real fast backwards and slamming on the brakes. He says that after that all 4 brakes are in the perfect spot. Is that true? I hope to have my car back on the ground this weekend and rebleeding and adjusting my breaks are the last two things I need to do.
Old Apr 23, 2010 | 12:13 PM
Ron Miller's Avatar
Ron Miller
A lot of early self-adjusting drum brakes do adjust when the brakes are applied when backing up. However, if they're working as they should, you don't have to go "real fast" nor "slam" on the brakes. The self adjusting ratchet will move the star wheel on the brake if the play becomes excessive when the brakes are applied as a stop is made while backing up.
Old Apr 23, 2010 | 12:57 PM
JohnZ's Avatar
JohnZ
Originally Posted by Ron Miller
The self adjusting ratchet will move the star wheel on the brake if the play becomes excessive when the brakes are applied when a stop is make while backing up.
Except when the star wheel threads are frozen, which is quite common. I always remove the star wheels, separate them and clean the threads, apply a thin film of moly lube, and re-install them. The self-adjusters work fine IF the star wheel can turn.
Old Apr 23, 2010 | 01:26 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
JohnZ is correct...in addition to being 'frozen' I have seen MANY self adjusting mechanisms installed incorrectly and thus not work. Unless you have personally had the drums off and eyeballed their installation and condition I wouldn't trust them too much...
Old Apr 23, 2010 | 01:42 PM
Ron Miller's Avatar
Ron Miller
. . . . . . if they're working as they should . . . . .
Old Apr 23, 2010 | 03:06 PM
Pilot Dan's Avatar
Pilot Dan
The self adjusters in my 64 work quite well. I went through my entire braking system and corrected some places where Bubba had been and have really not had to touch them for adjustment since. I wish my 59 had them. Pilot Dan
Old Apr 23, 2010 | 03:22 PM
GCD1962's Avatar
GCD1962
As long as thethreads are clean as John Z stated, the self-adjusters work fine. You can back up slowly, apply the brakes and come to a full stop. Do this a few times and they are set.
Old Apr 23, 2010 | 04:54 PM
stratplus's Avatar
stratplus
What makes a self adjuster, self adjust?
Any way to install these in a 60-62?
Old Apr 23, 2010 | 06:22 PM
Frankie the Fink
Army
When you back up and press the brake a torpedo shaped adjuster 'unscrews' and expands the shoes...a 'star wheel' works against a stop that has a ratchet effect to hold the adjuster in place after it moves... When driving forward the 'stop' keeps the adjustment from loosening. The brake shoes have special slots in them to accept the adjuster and an extra spring holds the ratchet plate against the star wheel....you could probably retrofit adjusters on an older car but its just too easy to do it manually IMO.
Old Apr 24, 2010 | 04:37 AM
mechron's Avatar
mechron
JohnZ, is exactly right as always. i would never argue with him. johnZ,
i worked on tons of 63-64 vettes and chevys back in the day. the star wheel self adgusters are 4 corner specific, they would self adjust if just by backing up slowly and pumping the brake. it was a no brainer because just backing up every day would adjust the drum brake shoes.
Old Apr 24, 2010 | 08:58 AM
MikeM's Avatar
MikeM
Ya' can't go wrong when you take your info right oughta' the owners manual.
Old Apr 24, 2010 | 09:08 AM
Fawndeuce's Avatar
Fawndeuce
So what method do you guys prefer for non self adjusting C1 drums?
I think the book says tighten until there is some drag, and then back off one turn? I'll go look it up, I have to do mine.
Paul
Old Apr 24, 2010 | 09:30 AM
MikeM's Avatar
MikeM
Paul
Getting all four of them evenly adjusted is more important than how you do it, especially on the front wheels.
Old Apr 24, 2010 | 12:01 PM
Frankie the Fink
Army
On my Dad's car lot back in the '60s/'70s where many makes of cars rolled in and lots had manual brakes he always told me to tighten them up until you can't turn the wheel with your hand then back off 8 'clicks'. I've done that for years on too many cars to count with perfect results...
Old Apr 24, 2010 | 05:21 PM
TheSaint's Avatar
TheSaint
I changed the brake cylinders and shoes on my 64 this morning.
I was careful to check that the stop plate for the 'star wheel' really stopped the 'star wheel' for turnig the wrong way.That the stop plate was close to the star wheel.I also adjusted the star wheel a little so the shoes touched the drum a little before putting the wheels back on. I also cleaned and sanded the inside of the drums to make the real clean.
Tha car goes straight as an arrow after i did this job. So i am happy as long as it continues to work like this
Old Apr 24, 2010 | 05:26 PM
TheSaint's Avatar
TheSaint
This i did not think of: I always remove the star wheels, separate them and clean the threads, apply a thin film of moly lube, and re-install them
Why did i not seperate , clean and lubricate the star wheel as JohnZ did.I should have thought of that.
And i did not know that the star wheels did adjust when backing up and brake.I knew they are self adjusting but not how it works.
I tighten the star wheel so the shoes hangs on the drums just a little.Did i do a mistake by tighten the star wheels a little?
Old Apr 24, 2010 | 06:01 PM
MikeM's Avatar
MikeM
What you're calling the "stop plate is actually the gizmo that pushes on the star wheel to adjust the brakes when you stop in reverse. It doesn't stop the adjuster, it is what turns it.
Preliminary shoe adjustment is set with calipers to match the drum diameter then just slide the drum over the shoes. Since I (and most people I know) do not own the calipers, I just rotate the adjustment tight enough to slide the drum over the shoes, step on the brake pedal, and adjust again if required. The self adjusters will take care of the rest of it.
Anytime you remove the drums, you should check for free operation of the self-adjuster mechanism.
To Drum adjustment
Old Apr 24, 2010 | 06:34 PM
TheSaint's Avatar
TheSaint
Sounds that ithe adjustment i did was okay then
But i cant see ho that gizmo tuns and adjust the shoes. But i really dont know much about drum brakes.
I might have to take the wheels off and lubricate the self-adjuster mechanism just to be sure.
Old Apr 24, 2010 | 06:49 PM
Old Blazer's Avatar
Old Blazer
Do any brake shops "arc" the brake shoes to match the drums once they have been turned? I haven't seen one in years.
Old Apr 24, 2010 | 06:54 PM
MikeM's Avatar
MikeM
Arcing brake shoes went away about thirty years ago. In lieu of arcing the shoes, it's recommended to replace the drums when they get a little OS.
