A/C Question
If I replace the A/C compressor without hooking it up to the system (just so the belt can be adjusted and turning) along with the accumulator and the orifice tube, would I be able to drive the unit to the repair shop the have the system evacuated/purged prior to the necessary recharge???? Any help or advice would be appreciated.
Thanks Jeff. That's what I needed to know. I thought that was the case but wasn't sure and wanted to check.
Steve
You mention an orifice tube and an accumulator? These were not originally installed, so I take it you are installing an aftermarket system?? Are you also converting to another refrigerant (ie 134a)??
The original system had a RECEIVER/DRIER just downstream of the condenser. This contained a dessicant to remove moisture. Maybe this is what you called an "accumulator". Any dessicant should be changed/replaced just before evacuating and charging with refrigerant. Since the dessicant will quickly pickup moisture, get to the AC shop soon after installing.....don't wait a few weeks......or have them install prior to evacuation and charging. Also, somewhere in your commissioning/startup process, you need to do a leak check and fix any leaks. The dessicant is best changed after the leak checking process is complete, and you know you have a tight system.
Larry
Larry
Larry,
You are correct, they are calling the accumulator what is actually the receiver/dryer. I am not sure what the orifice is but in everything I have read it says to replace that item also. So, I will do so. I have already had the system checked for leaks. The compressor was where it was leaking. I had it done at the Chevrolet dealer here. They wanted over $800.00 to replace the compressor, reciever/dryer and the orifice. Of course that was with new GM parts. They only provide a 1 year warranty on the compressor. I can buy re-man parts for a lot less, install them and have a reputable shop do the evacuation and charging. This will keep the 2 year warranty on the re-man compressor. So I will go that way.
Steve
Unless you just want a new (or reman) compressor, the seal is easily replaceable by an AC shop. The early GM compressor is one of the easiest to replace and the last one I did, used a ceramic seal for longer life. That would cost a lot less than a new (or reman) compressor.
I'm Steve too
The closest thing to an "orifice" for the older systems is the EXPANSION VALVE. Note that expansion valves should have a small inlet screen installed to catch any debris/dessicant from the receiver/drier.
GM went to a CCOT (cycling compressor orifice tube) system in the mid-1970's.....and this is what most systems are today. So that is how most AC repairman/mechanics talk nowadays.
Let us knw if additional help is needed.
Larry
