Electrical help needed
Old Apr 26, 2010 | 08:51 PM
Bud2's Avatar
Bud2
Bud2
Default Re Brakes
Make sure the contact pins and their respective contact springs are clean at the horn button.
Bud.
Old Apr 26, 2010 | 11:31 PM
KC66's Avatar
KC66
OK I think I got all the problems solved. I think Jeff and Geek got me on to something when talking about the temp gauge being grounded. Started checking with a probe and found when I grounded the 3rd terminal(only screw stud with nut) gauge seemed to work, so I made a small jumper and grounded it. Seem to work more normal now. Question, was there supposed to be a spade terminal there on the third stud? Mine didnt have one. Also brake lights work now unplugged and reconnected the two curved plugs on the colum and seems to work now. I think I may have to add some additional grounding under the dash, seems to have caused a few problems for me. Thanks for all of you guys that gave imput to my problem, you are the GREATEST!!!!! KC
Old Apr 26, 2010 | 11:38 PM
62Jeff's Avatar
62Jeff
Nope, no spade terminal. The temp gauge gets it's ground from the cluster. Sounds like you may have an insulator between the gauge and the cluster, and possibly fiber insulators serving as washers on the mounting studs. In any event, properly grounding the temp gauge does matter!
Glad you got it resolved.
Jeff
Old Apr 27, 2010 | 12:00 AM
63 corvette's Avatar
63 corvette
Wow, I am impressed! 28 hours and this electrical nightmare has been solved. Just think if the car was taken to a repair shop. How long would it have taken and how much would this have cost. Nobody could know for sure.
