Radiator replacement
Old Mar 22, 2002 | 10:08 AM
bigblock66vette's Avatar
bigblock66vette
Default Re: Radiator replacement (Tom DeWitt)
I agree with you on the purchasing from forum supporters, but to me money -is-money.
William
Old Mar 22, 2002 | 10:37 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Default Re: Radiator replacement (66 SC'ED VETTE)
66 SC'ED VETTE:
Do you know the name of the dealer in NC and where he is located? Just curious because I called Griffin in Piedmont, SC and was told that they had no dealers in NC. I ended up buying a 6561AF-BXX for a '62 from Summit for about $536.
Old Mar 22, 2002 | 12:01 PM
bigblock66vette
Default Re: Radiator replacement (cbernhardt)
I called Griffin themselves and told them where I was located, and they gave me the number. I Spoke with Ron at Griffin and he is the one that gave me the number. Hope this helps.
William
Old Mar 22, 2002 | 06:07 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
When you're ready to buy, call me. I will beat anyones price, period. But If price is such an issue you guys should really consider the least expensive model instead of trying to find the lowest price on the largest tubes. Bigger tubes do cool better but here me out for a minute. The big jump is the upgrade from copper to aluminum. Picture a ladder with ten rungs. Changing from copper to aluminum moves you up seven rungs. Going to the larger (1.25") tube moves you up one more rung, the 1.5" tube moves you up two rungs. These increases in cooling capcity are small compared to the copper/alum upgrade. There are about 4-5 aluminum radiator manufacturers in the U.S. from Visteon, Delphi, Fluidyne, thermal systems, C & R, none of these companies even make anything bigger than a two row, one inch tube radiator. If that is good enough for nascar, it's good enough for your corvette. 6266 rads go for under $500
Old Mar 23, 2002 | 01:57 AM
Mike Miller's Avatar
Mike Miller
Tom,
I am ready to buy, so lets talk. I am building a small block that should produce 425 HP, I may put AC on the car and I may put a automatic trans it one day but not soon. I need a radiator that will bolt in with no mods and will handle the maybes above. Give me a good price (delivered to my house) and I will support this forum.
Mike
Old Mar 24, 2002 | 03:15 PM
thorin's Avatar
thorin
i'm looking for an aluminum rad for my 454 big block crate engine, currently residing in my 67 convertible. do you have a straight replacement and if so, what are the specs and how much? thanks,
Tom
Old Mar 24, 2002 | 05:52 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default Re: Radiator replacement (thorin)
Thorin, what core support is in the car now? If it's a 66-67 bb (22.5") core, use a Griffin. If it's still the stock small block (19") core support, I'd stay with the factory aluminum Harrison/deWitt rad. As pricing goes, email me direct with the answer and I'll quote you pricing on a few options.
Many people, almost everyone, asks me "do you have a direct fit model for my car". Both Dewitt and griffin rads are designed to fit the factory core support, mounting bracket location, hose connection size and location for all years. Nothing we sell, requires modifications of any kind.
Old Mar 25, 2002 | 01:30 AM
gilbybarr's Avatar
gilbybarr
Well, took the '65 cruising today with the new DeWitt radiator in it....looks like success in keeping the temp down at 65-70 mph highway cruising. It used to hit 210 or above if I drove over 65 for very long....even in moderate weather like today (74 here in Knoxville). Today cruised at 70, even some 80 and it never broke 180. The real test will be when it hits 95, but this is progress!
:seeya
Old Mar 25, 2002 | 10:54 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default Re: Radiator replacement (gilbybarr)
Great news, what kind of radiator did you replace? td
Old Mar 25, 2002 | 11:17 PM
gilbybarr's Avatar
gilbybarr
A correct repro stamped and detailed to NCRS specs. Its a 327/300 hp car.
Old Mar 27, 2002 | 01:41 AM
NBlue396's Avatar
NBlue396
I have Harrison aluminum radiator on my 65 big block. Just bought car recently and it had new radiator. What originally came on car? Is there a difference in the cooling between the Harrison and the other brand radiators?
Car idles warm (225) and continues to heat past 225 while idling but cools down on highway to 190. This is on 70 degree days so I am wondering about summer? I am putting seals on tomorrow to cover gap (1/2 inch) between radiator and shroud as suggested. Would appreciate any other suggestions!
Old Mar 27, 2002 | 01:58 AM
pittsaj's Avatar
pittsaj
Trust me,
You won't have any problems when the weather heats up..
I have the same setup as you..
With the AC on and 90+ she runs 180 to 190 all day..
I used to run 210 to 220 under the same conditions..
Long lights were a real drag, was forced to shut off the AC or fear overheating...
I don't even worry about the gauge anymore
Even long lights will rarely bring it even close to 200.. :)
Well worth the time and $
Not to mention the peace of mind
Tony
Old Mar 27, 2002 | 02:59 PM
  #33
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default Re: Radiator replacement (NBlue396)
Most people don't pay very much attention to radiator, unless there is a problem. My guess is that your existing radiator is a copper/brass replacement and yes there is a big difference in materials and brands. The original Harrison aluminum radiator would have no end tanks and resembles an AC evaporator. The copper rad would have end tanks, which look like valve covers. If you have a c/b model you can drop the temps by 30 degress or more by switching to aluminum. Use either the correct repro $695 or the Griffin replacement $495. I have both in stock. It's funny that most people agree with me that changing a C/B car to aluminum is an upgrade but don't agree when I suggest changing an aluminum equipt car to c/b is a downgrade. It has to work both ways. td
I just realized you said 65 BB or 396. That's a classic car and I wouldn't think of putting anything in there but the factory Harrison model. It's more money that the small block but that car should be preversed, I think. Here's the real macoy
www.dewitts.com/pages/productdetail.asp?prodID=7
[Modified by Tom DeWitt, 1:04 PM 3/27/2002]
